Timing wire on 95 Tahoe
retorq
Kingman AZ
So I got my heads and intake swapped, Vortec TBI. I need to reset and verify the timing. I do not know where the ESC wire is that needs to be disconnected. I did a quick search and can't seem to find it. Does anyone know with 100% certainty?? I've read on other forums it's under the glove box but I don't see one ... 95 4 door if that matters. I'm just hoping to get it running well enough to get back and forth to work right now. Borrowing the gf's Ford is getting old. LOL
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Adjustments
WARNING: To prevent possible personal injury from a moving vehicle or operating engine, do the following before performing the checks:
Engage the parking brake and block the wheels.
Place the transmission in neutral.
Refer to the Vehicle Emissions Control Information label under the hood. Always follow the Vehicle Emissions Control Information label procedures first before using the following procedure.
Put the IC system in the bypass mode by disconnecting the "set timing" connector. This is a single wire sealed connector that has a tan with black stripe lead. This connector breaks out of the wiring harness below the heater case in the passenger compartment.
With the ignition switch "OFF," connect the pickup lead of the timing light to the number one spark plug. Use a jumper lead between the wire and plug or an inductive type pickup. DO NOT pierce the wire or attempt to insert a wire between the boot and the wire. Connect the timing light power leads according to manufacturer's instructions.
Start the engine, and aim the timing light at the timing mark. The line on the balancer or pulley will line up at the timing mark. The timing should be O°TDC . If a change is necessary, loosen the distributor hold-down clamp bolt at the base of the distributor. While observing the mark with the timing light, slightly rotate the distributor until the line indicates the correct timing. Tighten the hold-down bolt, and recheck the timing.
Turn "OFF" the engine and remove the timing light. Reconnect the number one spark plug wire, if removed.
Reconnect the "Set Timing" connector.
retorq
retorq
Kingman AZ
Yeah I'm not seeing that ... can anyone snap a pic of it?? I have some sort of connector next to the distributor that may or may not be it ...
njJohn
Aberdeen, MD
It will be black/tan wire. If '95 has that black wiring cover on the passenger side. It would be behind there. Thats how my '92 is.
ps-My step-Father's late parents bought a few acres in Kingman. Sight unseen and a long time ago. After they died he was out west and checked it out. Out in the middle of nowhere. The road doesn't even go near the lots.
retorq
retorq
Kingman AZ
I seriously get about 5 calls a week like that. :(
When were they out?? Kingman has changed ALOT in the past 5 years. If the property is actually in Kingman and it wasn't accessible 10 years ago, it probably is now. If it's in Mohave County and "near" Kingman it's probably still the same.
njJohn
Aberdeen, MD
The taxes get paid to Kingman. But, I think its was still kinda no mans lands. They were out about 5 years ago, maybe 4. I'll give them the info. thanks.
retorq
retorq
Kingman AZ
If you get a parcel number pass it on, I can look it up, see where it is and see what's going on in the area. :D
steamroller
The South
Should look like that and if I'm not mistaken it's behind the relay cover on the firewall
retorq
retorq
Kingman AZ
I found it, on mine it was taped up behind the glovebox ... it was around the back of the wire bundle "hidden" I can take a pic and post it tomorrow. Now to figure out how to remove the computer. LOL
njJohn
Aberdeen, MD
Talked to my Mother. They were there 2 years ago. And its like 20 miles outside city limits. Nothing but desert.
rossida
