thehoe92 Lowered 3/5
clean454
let put them in in the morning
what time are u getting up?
and ill look and see if we need to use
the factory mounts
or the extenders
thehoe92
thehoe92
fo sho
The916
I'll wake up early early to get them in since I have a meeting at 10
clean454
what u have to be at work at 10????//
well u wanna get the shocks in before the meeting or after?
thehoe92
thehoe92
fo sho
The916
meeting from 10-11 and work from 4-8
either way works for me
I'm thinking do it before that way I can ride around on them for a little bit
89 chevy
Did the box weigh yours down to 30.5? Or what else did you do to lower it?
clean454
dude will i finnaly tell these people u bagged ur shit already! damn
aired out hes 26.5ish
thehoe92
thehoe92
fo sho
The916
---------- Post added at 01:12 AM ---------- Previous post was at 12:26 AM ----------
stock? :emotions122:
not stock! :rocking:
Modded
That Guy
Damn that ** is nasty low, my lowest ground-fender measure is 33.75 haha, 3.25" from you, too bad the NNBS Tahoe cannot go lower that 32" without bags!
89 chevy
What bags did you go with?
---------- Post added at 10:52 AM ---------- Previous post was at 10:46 AM ----------
Did you cnotch it too? Because the way mine sits, I only have 3in of travel before the axle hits the frame.
thehoe92
thehoe92
fo sho
The916
do explain max
we've got like 3 days left of mods I need some more to add to the list :)
Max
Mile High
Denver
Your panhard bar is pushing the one side of your truck farther over than the other side, removing a small amount of material from the middle of the panhard (track) bar and re-welding the bar will pull the axle back to center between the frame.
briannorris
