Whew! That's good because when I googled blowing forum, I didn't like what it brought up.Auto correct error hahaha - Boating forums or channels on YouTube
Don’t judge. That’s all I’m going to say.Whew! That's good because when I googled blowing forum, I didn't like what it brought up.![]()
That's super helpful insight - especially on the DC-to-DC charger. Thank you. This may be more info than you care to know, so I'm just laying it out here - more to memorialize it for myself and in case others see it and are also headed down the solar path.I have a 200Ah LiFePo4 setup with a 20A dc-dc charger and a 2000w inverter. Renogy charger and inverter.
You are going to love the LiFePo4 setup! So much better than wet batteries!
With my 200AH i run a small fridge/freezer, Lights, TV, Keurig, Phone chargers, Charge the chain saw battery.
After 3 days, it'll be down to about 30% remaining.
I only have enough room to add a 100W solar panel to my van but will be adding it next spring.
1 thing i would do different though is the DC-DC charger. 20A charge takes forever to put any real noticeable charge back in the batteries even when highway driving.
Knowing what i know now, i would get a minimum 50A DC-DC charger and bigger alternator to handle the load.
As long as you didn't join any....well, even if you did....well, nevermind.Whew! That's good because when I googled blowing forum, I didn't like what it brought up.![]()
Looking good so far! Its nice they give you plenty of room to work with.Got the bed out and the compartment under it ready for wiring and swearing. Spent a good hour just sitting in there looking at the factory wiring, inverter, buss wires and junction box to make sure I understood every nuance. The factory positive buss bar is actually a set of 4 self-resetting breakers, which is cool but in all of my research I had never run across it so it hung me up a while while I sorted it out.
Got the battery in along with the Dihool breakers and about half of the wiring. The 4/0 copper lugs I had were too wide for the main breaker so I ordered 4 more in the right size.
Shockingly (har har), there is much debate online as to whether the main breaker (and all downstream breakers) in an RV should be on the positive or negative wire, with the only point of agreement being that it needs to be as close to the battery as possible. Even ChatGPT was confused. So I just installed the main battery disconnect/breaker to the negative side because I know what happens when a positive wire gets shorted to ground when the negative battery terminal is still connected. And I suspect y’all do too.
I’ll install the downstream breakers on the positive wires to stay consistent with the existing Airstream DC wiring. I should be able to finish the rest of phase 1 of this long term project tomorrow, and load test everything.
View attachment 469158View attachment 469159
Yeah, it’s really well laid out. I guess that goes with the same company building RVs for 80 years.Looking good so far! Its nice they give you plenty of room to work with.
Nah. She knows I know how to lay cableIs wifey freaking about about you tinkering on the new RV yet?![]()
Should have great weather from what we are seeing. We will be leaving NC this weekend/early next week for Erie area to see the family for Thanksgiving. Safe travels!Final mod for the fall is a 3” lift kit on the Airstream. We like to boondock off the beaten path, so this will keep us from dragging our ass on the way in or out.
I didn’t feel like tackling this one so I farmed it out to a local guy who specializes in Airstreams. Cost me 1200 beans for the labor, but it’s done right. As part of that, he set up my hitch for the lift and he’s a master. The Suburban 3500 rides even better now with the Airstream behind us.
Off to the OBX with it on Tuesday for the Thanksgiving holiday.
Gonna be cold for a couple days but we’ll manage. I know Erie very well - lots of friends and family near there. Safe travels to you also!Should have great weather from what we are seeing. We will be leaving NC this weekend/early next week for Erie area to see the family for Thanksgiving. Safe travels!
Thank you, my friend!Looking good my friend. Safe travels!
