Tahoe want start
Devonna623
My battery want stay charged bt I still have power bt not enough to start my truck. Put a new battery in and it still want start.
You mean it won't start? What does it do when you turn the key? Do the headlights work?
Repaired_Tahoe
Im having the same problem (I put the engine replacement on hold for now) my truck doesn’t get driven I only move it around in my driveway. I’m just confused because earlier this morning the truck started up just fine but a few minuets ago it wouldn’t start..The headlights came on when I unlocked it and everything but when i turned the key it wanted to start but it wouldn’t turn over and the battery is about 2 years old.
If you don't actually drive it for more than short trips the battery will slowly drain. There is a known issue that idling will not sufficiently charge the battery, and 5-10 minute trips will do the same, so if all you're doing is starting it up and moving it around, your battery will go dead. You need a battery tender to keep it charged.
Bob LaFord
