Switched Power to Rear Outlet?
BobMc
2009 LTZ
I have found a switched power source under the dash. I now use it to power two switched outlets in the console storage "bin".
Question--
Is there an easy way to run wires from that source to the outlet in the rear of the cargo compartment and change that outlet to a switched outlet?
Thanks!
taylorjm
Saginaw, MI
You might try looking in your fuse box. Mine is older but the box on the drivers side dash panel has the fuse for the power outlets. You can reroute the power from there to a switched source if you have one.
BobMc
BobMc
I have the source as noted above.
I'm just looking for help with the routing and pannel removal/replacement.
Thanks,
Bob
dizhai
