sway bar issues with end links
NORCAL SS
SUV SUSPENSION GURU
No only time it would break is if it's installed wrong which is bar on inside. You can grind off the edge also. More than enough meatvin bracket.
Deephaven
Scary how much it rubs on a lift...makes you not want to drop the truck. Kartoon curious if you found a solution and if you could post pics.
NORCAL SS
SUV SUSPENSION GURU
It rubs on lift be a use tites off the ground and entire rear end shifts,with no weigy. When drops back down it shifts,it all over
southboundchicken
Jacksonville fl.
Well here we go fellas.... Im installing the 2/3 drop kit and having the same issue.... Im moving to the front to finish the install then returning to the rear afterwards to address this issue
NORCAL SS
SUV SUSPENSION GURU
Please send pics. I just did a tahoe yesterday cleared fine. Did you relocate drivers side bracket on axle? There are varieties on rear bracket on panhard so on some you have to tap it in.
southboundchicken
Jacksonville fl.
Im still wrenching the front, been installing new ball joints and tie rod ends so its taking a bit longer but hope to have it together friday and i'll jump back to the rear to address the end link situation and report back
rossida
