Suspension Squats when loaded down
ChiefTahoe
Hello, I have a 2002 Chevy Tahoe 4wd, which has a 2” lift along with Bilstien shocks, unknown what springs. I also have upgraded brakes from PowerStop, which are meant for lifted vehicles and for towing. I tow a 7x16ft trailer regularly picking up scrap and occasionally towing vehicles. I’ve noticed when it is loaded down it squats pretty heavily, I was wondering what I should do to help reduce the squat and unnecessary stress on my drivetrain and suspension. I’ve included some pictures of my truck, one showing the squat, front suspension, a random picture of the rear while doing repairs, and a normal picture.
Welcome to the Forum from NH.
I think that your best bet is to get air bladders that fit inside your coil springs. If you have an air compressor at home, you could fill the bladders to level your truck, when carrying a load, and release the air, when you're not. If you want to expand your budget, you could get an onboard air compressor, and then be able to inflate/deflate the air bladders anywhere, anytime, as needed.
afpj
Curious, what rpo codes do you have for your suspension? What was the original suspension?
dps01
Senior Member
Navy Supporting Member
N. TEXAS
Z71 rear springs, air bladders & Timbren bump stops for good measure…
Likely not all required, but had them from various projects…
C
ChiefTahoe
Thanks for the welcome, I will definitely look into some air bladders, is there any brand that you recommend?
C
ChiefTahoe
I will definitely look into some z71 rear springs and air bladders, I didn’t think about getting new bump stops since I recently replaced line lol
C
ChiefTahoe
I’m not sure what the original suspension was as when I bought it, it had already been replaced and lifted. I’m not sure what the rpo cards are, but I believe you are asking for this?
Well for starters, you're squatting so bad because the truck is missing a couple hundred pounds with the front bumper removed.
The 2 inch lift also contributes to the squat.
Your truck originally came with Nivomat self-adjusting shocks out back (ZW7 paired with G65). Judging by those photos, they're long gone. If memory serves, the springs paired with the Nivomats are much softer than a Z71 or plain ZW7 setup. Those use the Dorman 81069 or something like GM 25783733 or ACDelco 45H2164/19255624.
C
ChiefTahoe
Yea I’m sure some of it is because of me not having my front bumper on, however even with the bumper on it still squats pretty heavily. I’m looking to get a new off-road bumper eventually, but currently I’m painting my current bumper because the trim piece after I replaced my bumper didn’t match the color of my truck. I didn’t think the lift would have any impact on my towing. Yea the old owners decided they wanted to lift the truck and change the suspension. Well it looks like I’m replacing my springs. Thanks for the advice
LsHart
Senior Member
Shocks and struts, the actual strut shock, they keep the tire on the ground and springs and coils push the vehicle up. So stiffer springs fight the sag.
CRN_25
