Suspension Lift For 285/70-17?
MiamiDave
I want to run 285/70 17's (32.7 inch) on stock rims and offsets. Will they rub with a 1.5 front suspension lift (w/o cutting)?
bmxdannyo
San Antonio, Texas
yes they will rub, not alot. You will need to do some cutting. If you havent already bought your level, id go with the 2.5 front and 1.5 rear kits. either by truxx or ccm. If you already have your level, its not alot of cutting you would need to to. If you have factory lt steps: either take them off or cut them with the body line, you will see that they go past the body line and close into your tires. Grab a jig saw or grinder and carefully cut. Taking them off is easier, i had to keep mine on because of kids.
M
MiamiDave
So just raising my tire width 1 inch is going to rub and scrape?
scottd
