Strobes
jpmaniac87
Mississippi
I've got them from Speedtechlights.com... They are 80 watt I believe and plenty bright enough. I have 2 in the DRL slots and plan to put them in that side part of the headlight
jmildoc
jmildoc
Indianapolis,Area
you think they will fit? its pretty thin. i like my DRL's, when they work i think my relay went bad, when i was trying to connect them to my headlights with a diode.
NJ04HOE
Paterson, NJ
Who has strobes? Where are they, and where did you get them from!!
I got mine from here...http://www.lshlights.net
I have/had two 90 watt six bulb kits, six in the front and six in the rear. The reason I say had is I got pissed one day and took out the power supplies but the bulbs are still in I just gotta get around to putting them back.
Long story short....my trans started acting up not long ago and it crossed my mind for some stupid reason to trade my HOE in and just get rid of it. But I found out I still had time left on my extended warranty and two days after I jumped the gun and snatched them out my HOE was in the shop getting the trans rebuilt.
HMFDZ28
Hunt Sta, NY
Dunno what you are lookin to use them for but whelen makes the best setups. I build the occasional Chief's truck at work and well we tend to use whelen for all of our lighting. Being a Voli I have a 90watt 6 pack in my Z28 and once I bite the bullet and buy the Z71 she will have a strobe setup also. I strong recomendation is if you are only doin it for show Whelen just started releasing LED strobe kits... much lower current draw. Just be prepared to drill a 1" hole where you want to add the strobes.
Josh
Milwaukee, WI
I have got four. Two in the side of the headlights, and two in the reverse lights.
NJ04HOE
Paterson, NJ
what do you need them for?
x2 on the whelen
I used them for show at events,car shows and sometimes just for fun when there's no cops in view.
They're legal (where I am) as long as the vehicle is parked and your not using them in traffic etc.
HMFDZ28
Hunt Sta, NY
I agree with ya there. If you use them alot then spend the little extra and buy a whelen kit... you can find a ton of them on Ebay for good prices.
jmildoc
jmildoc
Indianapolis,Area
if i am working on the side of the road, trimming trees or pulled over with my trailer or anything like that..... I am looking for an air horn tooo... but that is for other reasons
bdd012
Souther NJ
i have them in my parking lights and in my taillights. i have a whelen 90watt power pack. got mine from needlights.com. i use them for going to my firehouse for fire calls. very easily seen. i wasnt sure at first about the parking lights, but i love them now. for air horns i suggest airhornsof texas.com.
Repo503
I used to hear stories of a crew up in washington that has two black tahoes with strobes and they would pull over and rob mules coming down from BC.
bdd012
Souther NJ
i believe what he is talking about is taking out the DRL bulb and putting the strobe blulb there instead. deleting the DRL feature
HMFDZ28
Hunt Sta, NY
Here is a crappy vid of my Z28's lights. Camera couldnt catch the pattern correctly.
http://www.youtube.com/watch?v=GryzLvHEyuA
The headlights have clear strobe tubes and the corner lights have blue strobe tubes. Thats a Whelen 690 pack... supposed to have two clears in the back but just didnt install them. The Dash light and two grill lights are Blue/White LEDs. Just for an example for ya.
JeffK
