Stock Radio
GangstaCowboy
Hello-
I am looking for some info on stock radio's that are compatible with a 98 GMC Yukon. Can anyone point me in the right direction? Thank you
_Dylan_
STAY FROSTY
You should be able to plug in most GM delco radios from the late 90s into your truck. Maybe even early 2000s.
noJeepshere
Bountyfull, Utahrd
Any GM-9 radio will be a plug-n-play affair. That means any stock radio from 1995 to 2003 fullsize GM will fit your truck. Some of the car radios will fit as well but I'm not sure which. The thing you're looking for is if the radio you want to put in has a 9pin plug in the back, if it does, it'll work.
mfinta
