steering stabilizer
smrr1
i understand that my 2 dr 4x4 does not have one from the factory but how do i go about installing one on my stock tahoe? not going to be lifted or anything. just some 285s. i am just hoping to tighten it up some. it likes to wonder a bit. anyone have a pic or a write up of a factory hoe with this?
looking at rancho
http://www.dirtdirectory.com/MARKETPLACE/productDetail.php?pid=560767
S
smrr1
never. it's done very little driving since new!!! (28K) I am a bit new to the vehicle and would just like it not to wonder so easily. i am also looking at front and rear sway bars. it does a lot of highway driving at 70ish and with the 285 nittos it tracks the road a bit. already had an alignment. helped out a bit but looking for something more.
sparg93
Expedition Tahoe
NJ
front sway is really heavy, i would personally leave it alone.
The rear is skinny and would really be the only one to change.
personally i just changed all of the rubber bushings to polyurethane to tighten up the hoe. Other than rusty bolts, it's a really easy upgrade and pretty inexpensive,
S
smrr1
some people have said they do not have the sway bars. i will have to check since i have not really looked to see if mine does. i am also looking at replacing the shocks. i know it doesn't have many miles but 11 years is a long time to be sitting on the same ones. i have had single cab short bed trucks before and was kinda hoping to have the same driving characteristics but it doesn't!!! i am just trying to get it a bit more stable at highway speeds.
sparg93
Expedition Tahoe
NJ
there is a thread on here somewhere for you 2dr guys w/o the rear sway...they purchased one and then crafted the mounting brackets..seemed pretty easy from reading the thread.
I have Bilsteins on mine and love those shocks.
S
smrr1
hellwig actually sells a kit with everything you need
blizz
San Antonio, TX
I bought new pro comp shocks a few years ago cuz they were having a sale at 4wheel parts and the package came with a steering stabe but I never put it on because I didn't know where to put it. I've been told that if I want a really nice ride to get some bilsteins so when I have to replace them I'm using them.
S
smrr1
I am in the same boat. I don't know where it would go. No factory brackets for a factory one.
Grebbler
Parts is parts...
Michigan
Oddly enough, I just put a KYB on my Hoe. Would you like to read about it?
Of course you would!
My truck also wanders a tad and I was getting pulled into ruts and stuff so I install the Single unit KYB SS15326 kit (all hardware included) from Rock Auto for about $60. I didn't want to crawl under the truck in the snow to go through the entire front end so I thought the stabilizer would help until summer. Installation was a breeze and I can really fell the difference. Unfortunately, it's not all roses and song and I will try to describe it all so you can decide for yourself.
Background info for others who may read this:
A stabilizer is a horizontally mounted shock absorber mounted to the frame on one end and the drag link on the other. It resists side to side steering motion or "Bump Steer" induced by the tires hitting bumps and ruts. If you ever watched Overhaulin' how they steer the car going into the paint booth by kicking the sides of the front wheels while pushing the car; that's a good example of bump steering.
The Good:
Holds the wheels pointed in your chosen direction (unless you have bad wheel bearings). You won't feel any steering wheel pull when changing lanes over rutty roads and pot holes.
Steering feels more solid.
The Bad:
Holds the wheels pointed in your chosen direction. The wheels won't center themselves coming out of a turn like they used to.
It won't help any with wind shear. You won't even feel the tug at the wheel anymore - the vehicle will just be 8 inches to the side without warning.
All those unconscious nudges you give the wheel to stay in your lane will be off along with your timing. Not drastic - just irritating.
Any dead spots or play in the steering wheel will widen a bit.
Sideways forces acting on the tire get transmitted to the frame instead of the steering wheel so the truck may vibrate more (great for feeling worn wheel bearings).
Puts more strain on the steering gear box and Pittman arm.
Steering, especially quick paced rally style, is a bit slower and takes more effort.
For me, the jury is still out whether I like the swapping of old irritations for new ones. I plan to do any Pittman / Idler arm reinforcing mods and replace any worn stuff in the summer and try again with and without the stabilizer to see if I wanna keep it on there. I run stock wheels and tires, can't off-road around here and I haven't gotten enough snow yet to see if it helps.
Still, it's cheap and easy enough to install to see if you like it.
Hope this helps a bit.
bowtiefreak
No Quarter
Near Philly
I ran a rancho and the wheel did center itself, if it does not it might be binding somewhere. The install is a snap. a few little u bolts hook to the tie rod and the other side mounted up using one of the skid plate mounts. Could not really tell a difference in running it
S
smrr1
awesome write up. thank you very much. i think a few of us will find this helpful. i was not aware of some of the negatives. i will have to check up on some of those. i was a bit concerned about the wheels/tires not centering after a turn but BOWTIEFREAK has had a different experience. maybe i will just take the hit and buy one to find out for myself. surely i could sell it on craigslist if i don't like it.
can someone post a close up/detailed pic of this on a stock tahoe?
Grebbler
Parts is parts...
Michigan
I should have been more clear. It does center for the most part, just not all the way at low speeds or as much as you might be used to.
I'll see if I still have the instruction sheet but it's really easy. I will describe how I did it.
Put the truck on ramps or jack stands with wheels centered (you may need the extra room for the drilling part).
Remove the rear mud or skid plate (mine is plastic) that covers the steering stuff. I think they were 5/8 bolts (4). This will allow open access to the drag link.
The kit has two mounting brackets, 4 U-bolts (2 sizes), a shock and some hardware. You will need a drill, 5/16 bit, and a socket or wrench set.
Grab the larger 'L' shaped (frame) bracket. One side has two holes of a different size and the other side is a longer tab with a single hole. Using one of the bolts you just removed from the skid plate, mount the bracket with the tab sticking up using the larger of the two holes (duh - bolt won't fit the other hole) under the drivers side where the bolt came out of. The smaller hole should be over an angled portion of the cross member and the tab will be parallel with the wheels. You can now drill up through the smaller hole into the cross member and install the provided bolt, lock washer and nut or you can do this later if want to be sure of the position of the bracket.
Leave that for now and get the shock, the other bracket and the two baggies of shock mount parts. Put a cup washer then a rubber donut (smooth side first) onto both ends of the shock. Measure the piston travel of the shock and remember it (mine was 8 inches). Thread the BODY end of the shock through the hole in the tab of the bracket you just mounted. Make sure the small donut flange centers into the hole. Follow that with another donut, flange side first then another cup washer and a nut, Tighten the mess snug making sure the donuts are still centered in the hole.
With the wheels centered, pull the piston 1/2 way out. Mine was 8 inches so I set the piston at 4 inches. This assures the most travel each way so the shock wont bottom out while turning. Thread the other bracket onto the shock up against the donut and up against the drag link and check for clearance. The bracket can go either way but I mounted mine with the U-bolts holes behind the shaft as I wanted to leave some room around the idler arm.
Once you have decided what you'll do with the bracket you can either leave it on the shock and install the other donut, washer and nut or you can push the piston back out of your way to mount the bracket onto the drag link using the proper size U-bolts. I was beating the snot out of a U-bolt and cussing before I realized that larger U-bolts were included. It was night and I was lying on them :)
Clean the area of the drag link that the bracket will go of mud and grease if needed. Snug down the U-bolts but leave them loose enough to slide the bracket along the drag link. With the shock mounted and the rest put together, make sure the piston is still 1/2 of the way out. Move things around until the shock is straight and parallel under the drag link and there is room all around the shock and the brackets are straight.
Drill that hole and install the bolt if you didn't do it yet. Tighten down the drag link U-bolts and the ends of the shock (until the donuts bulge about 1/8 wider).
Remove the factory bolt from the frame bracket and reinstall the skid plate. There are washers provided to go between the frame and the skid plate on the passenger side to even things out and make up for the bracket thickness on the other side.
It took me longer to type this out then it did to install the bugger!
Have fun! :party33:
S
smrr1
very awesome and again thank you very much!!!!!!!!!!!!!!!
RKitagawa
Los Angeles
Hey fellas,
I have the same issue and haven't found a cure yet. Everyone mentions getting a steering damper, however I am quite sure this will only be a temporary fix until I figure out what's going on in the front suspension. Rather than invest in the steering damper and hope the issue resolves, I much rather start swapping the front suspension and correct the issue...then install the steering damper to prevent it.
Not knowing much about cars, does anyone have images that can help me locate all the steering components of the Yukon 01 and what they do. I do know the tie rods, however I am lost when it comes to all others such as the ones below.
Pitman arms
Idle arms
Ball joints
Bearings
U-Joint
Steering box
Control arm bushings
My Yukon does have sever Bump-Steer and it drives me crazy. Never did it before until about a year ago. I constantly check my alignment, balance, rotate, have new tie rods, get the suspension checked with all shops (Midas and Pepe Boys) and yet nothing
seems to work. If I could narrow down the items above while getting it fixed, that would help tremendously.
TigerEyz3
Slow and Steady
TN
Could someone shrink that picture? My eyes hurt.... wow. A description of the parts is below:
  • The pitman arm is the piece that connects the steering gear (following the steering column to the end and you can't miss it) to the frame and drag link.
  • The idler arm is at the other end of the drag link and connects to the passenger side frame.
  • Ball joints connect the control arms to the spindle (where the wheel mounts)
  • Bearings - assuming you're talking about wheel bearings, these are what the rotors spin on.
  • U-Joint - take a look at your rear drive shaft. At the differential end, you'll see a u-joint. It connects the drive shaft to the differential and allows suspension flex without binding the drive shaft.
  • Steering box - at the end of the steering wheel shaft. Has the power steering fluid in the reservoir. Connected to the pitman arm.
  • Control arm bushings - control arms connect the spindles and ball joints to the frame. The bushings allow up/down deflection without binding or metal-to-metal contact. To see the bushings, it will be easiest to remove the front tire(s) and look at where the frame connects to the front suspension.
Hope that helps your understanding a bit....
Hodmjstone
