so you have 2 Tahoes that make the same ? Start and die strange . Friend of mine has a 2003 Tahoe and his ride makes the same. Starts and dies. But in his case the problem only occurs sometimes.
We are now checking the ECU / the sensors.. First we will check the value of the Cooing Water Temp.Sensor...
if he sends false information to the ECU ; for example 0 deg when it is 65 Deg ..then the engine get too much fuel. Result flooding..
