Stall out
@BG1988 I had crazy electrical issues including truck not starting to losing power on the freeway after a carwash one day. It ended up being the negative battery cable. I could tell because when I jiggled it my electrics would flicker.
Oh no here we go...welcome to Bretts world.:crazy:
B
BG1988
well it worked good for a while after replacement of the battery
then the issue started again
after i cleaned up the power cables
worked fine for a while then it came back
change the MAF sensor (IAT was incorrect)
worked fine for a while then the issue came back
I thought it was the MAP sensor?
thompsoj22
That is definitley the "Terminator, Ill be back" code! Hey, each time you fiddle with the bat cables it has an effect, Change the cables or cut and swedge new ends to rule them out completely?
exp500
And then there are trucks that punish you for fixing them. Tighten the rattling door, lose your AC. Long list and I know I'm not alone.
Let’s hear the list. Never had a truck do that to me, maybe I’m lucky?
raidernationmike
Redondo Beach, CA
tighten all the posts and mounts to the chassis. Simple check may help remove the electrical issues. Mechanics often forget to tighten the posts after doing any basic work requiring to power down vehicles
B
BG1988
turns out it was my air filter that was clogged up with fine powered dirt
RanchoTexas
