Spark plugs
cam3439
I have been using the Bosch +4 Platinum-Iridium Fusion spark plugs for 2.5+ years now and the engine still runs really smooth. I used Bosch before and decided to put these on the hoe.
Thumper8302
OKC, OK
+1 ON THE BOSCH...... been lookin at those pulsars or pulstars whatever u callem.... prolly gonna stick with the Boschs since i been usin them along time especially since those pulsars are $15 a pop
cam3439
I don't really know about those pulstar's because we installed a set on a friend's 5.3L Monte Carlo SS and when we took out a few after like 3-5k they really looked like crap. They looked excessively worn, and that was with a motor that only had 15k on it. So he opted to go with a set of Bosch plugs.
Thumper8302
OKC, OK
well then u def sealed the deal for me then..... sounds like they might make a good plug for a lawnmower ha ha ha:Plugged:
puckhead
CO
Im running NGK. 55's I think. Several people on here have em. Works great and if you make the gap .04 even better!
puckhead
CO
Couldn't tell you an exact answer but this is what I remember of what I was told. It shortens the gap for the spark to jump making it ignite faster and more efficiently. IIRC GM changed the OEM stats (dont know to what) for gaping plugs and this .04 gap is a step more towards performance. Maybe someone can chime in and correct/expand on what I said. hope this helps!
Thumper8302
OKC, OK
couldn't tell you an exact answer but this is what i remember of what i was told. It shortens the gap for the spark to jump making it ignite faster and more efficiently. Iirc gm changed the oem stats (dont know to what) for gaping plugs and this .04 gap is a step more towards performance. Maybe someone can chime in and correct/expand on what i said. Hope this helps!
it does make some sense....
rich5368
Cheyenne, WY
It's all about stock replacement A/C Delcos. I tried the Bosch +4, the NGKs, and couldn't tell the difference in any of em so I save money and put stocks in there.
Grebbler
Parts is parts...
Michigan
I think it also had to do with rough idle complaints.
I am still on the Iridiums at 152K.
HMFDZ28
Hunt Sta, NY
The NGK TR55's and TR6's are the most common;y used in the LSx community that I know of. I have TR55's in my Camaro, though stepping up to the TR6's for my heads/cam package. Truck will prob get a fresh set of TR55's them come time for a tune up.
Conor
"Bob's your Uncle"
Seattle, WA
There is no need to run anything other than OEM plugs unless you have forced induction. i.e. supercharger. It is a waist of money in my opionion.
Redhoe01
The BDG
Forney, TX
So I just bought Champion Iridium spark plugs for my hoe. Did I make a mistake or do you guys think they will be ok?
LaOrange
River Ridge La
Hi All
Replaced the OE AC plugs at 100K with the Same Stock plug
The OE looked VERY good with 100K so why change if it is not broke
do not try to fix it
Mckennahc
