spark plug and tune up advice???
cmcarr85
Ok well i just bought some ACDelco wires, cap, rotor, pvc valve.
now my question is what plugs? Do i go with the acdelco or the e3s?
Also what other things should be done while doing the tune up?
it already has a new air filter and oil filter...
blueflamed03
Oklahoma
I'd be curious on the E3's as well....they may add more slight power, but ACDelco's can last a long time.
C
cmcarr85
thats what im stuck on...
acdelco's are better known.. and the e3's are suppost to do all this good stuff but i think im gonna stick with the acdelco's...
96ProCompTahoe
IN
its been said by several people the delco's are the best for these engines. thats whats in mine. but the E3's aren't bad, though not in my hoe, they work amazingly in the mower. haha.
foreverfalcon40
E3's worked **** in my truck. Crank start up was instantaneous! I can't vouch for power though b/c I installed the e3 when installed my worked heads.
e3 come with 5 yr warranty. Can;t beat that.
A/C delco is GM recommended. So you can buy top dollar or generic ac delco plugs.
While doing your tune...don;t forget your fuel filter and do we have a caabin air filter lol?
Also check your hoses and belts for cracks!
P.S.
Have fun changing the last two plugs on each side!
haks310
Got LEDs?
SoCal
Both AC Delcos or E3s will work great.
Fuel filter
Fluids check
Grease chassi
Belt and hoses
LoL cabin filters weren't put in until 2002 IIRC
---------- Post added at 09:56 AM ---------- Previous post was at 09:52 AM ----------
BTW, when you put in the new plugs, put some anti-seize on the threads.
96ProCompTahoe
IN
wait till you have to change them with headers... my gibsons make it a PITA...
haks310
Got LEDs?
SoCal
NGK seem to work too, haven't personally ran them but have seen others who have.
foreverfalcon40
STAY AWAY FROM NGK
AC Delco is OEM
e3's are upgraded. I use e3's there fine. I recommend them. I don;t know why some members had problems with them. Maybe they dropped them and closed gap? I dunno.
My truck fired right up with them in it...compared to the trun key...starts turns for a lil and then catches. (My starter just has a lil over 11k on it). When I did the e3's it started right up as soon as I turn the key in the ignition.
MYNES
IM ALL IN
BrOoKlYn,Ny
i like the denso iridium plugs not sure if there good on our trucks.but when i had my maxima,g35 and charger thats the plugs i choose
jkalsch
I'm getting ready to do a tune up on my yukon. I'm planning on ngk tr55 plugs and delco wires. Rock Auto sells model#718q wires for $107 and #9718q for $64, is there a difference? Also, does the brand of rotor, cap, pcv valve, etc. make much difference, should I stick with Delco or are cheaper brands fine? Thanks for any help
Davyboy
Alberta, Canada
Well I'm running NGK platinum plugs in my kon now, its been running NGK copper for about (well it looks like they haven't been changed in about 250,000km (about 150,000miles) before problems occurred). I dunno I've always trusted NGK.
And the last two aren't as bad as everyone makes it out, I actually had more trouble with one in the middle lol.
C
cmcarr85
The delcos worked great in the truck but then again when I changed them everything looked like it was factory so I guess anything would have made it run better.
D Rollins
