[SOLVED] 2026 Tahoe Z71 Duramax Oil Change with Skid Plate
Radiotech1
I have a new 2026 Tahoe Z71 with a Duramax that will soon need an oil change. Do I have to take off both of the skid plates to access the oil filter and drain plug?
StephenPT
St. Helens, OR
I don't believe so. The drain plug and filter are both at the back of the engine. Just in front of the sway bar. Really easy oil change with a vertical filter and drain plug that doesn't shoot the oil onto the frame.
R
Radiotech1
Thanks! You are correct. I didn't slide back far enough when I was under it looking.
Stbentoak
Fumoto valve fixes this issue. Waste oil goes directly into container for recycle. Not one drop spilled. Best I have found for the filter is to drill a hole in its bottom and let it go into a plastic trash can lined bucket...
kikeap
