Show me the light!!!!
97YUKLVR
PA
Hi guys...looking for some advice on either upgrading or replacing the headlamps in my 97 Yuk....not concerned about looks as much as I need MORE light!! Im getting old and seeing at nite is gettin harder!
Can this be accomplished with simple bulb exchange or do I need to replace the entire lamp assy ...if so...which are the brightest/strongest??? Yes the lamp lenses are a bit foggy now, but even from new I woudnt say they were all that great!
stereodesigner
They make brighter bulbs that you can buy at Autozone, if I was you I would get HIDS (and projector headlight assemblies if you have the cash) just order the white HIDS and make sure they are aimed correctly
Sent from my DROID X2 using Tapatalk 2
ChrisAU
Birmingham, AL
I noticed a HUGE difference just by getting clear housings off eBay that are on my '92.
xanatost
Lafayette, La.
A easy fix. Take some 1000 grit wet/dry and wet sand it and then spry with some crystal clear clear coat.
Drewphil
