Should I use radiator drain **** ?
HDRock1
Flint,Mi
Should I use radiator drain ****, or just use the bottom hose to drain ?
Does the radiator drain **** on these Hoe's cause problems when U try to open or close them ?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
drain **** i think will be easier then hose and less chance of radiator damage. should be a cammed turning drain from what I remember. I would verify that tho.
JenneK
Island of Maui
If one was to read between the lines though you'd see the wisdom. :)
Old radiator drains can create larger issues than pulling the hose off the bottom.
And for the record, there are only two hoses I pull; mine and the lower radiator.
taylorjm
Saginaw, MI
I pulled mine after 10 years to drain the radiator. Didn't have a problem at all. I even bought a new plug just in case the o ring was bad or something, but didn't end up using it.
Drewphil
