Should I try running E85? Or stick with unleaded.
Chiller449
So out of curiosity I did a vin decode on my 2004 Tahoe. To my surprise it said I have the flex fuel 5.3. My dad has owned the truck since it had 150k on it. Ive owned it for a while now and its got 255k on it. Still running like it was new. Im 100% positive my dad has never ran e85 in it. As for whoever owned it before him I have no idea. Im just curious if you guys would suggest trying e85 or just sticking to unleaded. Im not sure if it would hurt the engine now that it has such high miles and never used e85 before.
Also here is the vin incase you wanna run the vin. The site I used looked a bit sketchy and may not be right.
1GNEK13Z34J214410
Big Mama
Virginia
E85 imo is for when that’s all you can find. It was supposed to be cheaothan gas back then but it never happened. In the boat world, I have a 350 in mine, ethanol is the devil bc it gums up if you don’t run it regularly. With today’s gas prices fill up with premium and give her a treat.
1GNEK13Z34J214410
Vin Z, L59 motor right? You can run E85 with no ill effects. The truck will love it, it's like burning cheap racing fuel. Try a couple of tanks, one isn't going to give you a good report of E85s performance or your truck on it as the alcohol content will be diluted from the previous fill. On the other hand, if its really cold where you live, know that it might stall on start up as the fuel in the lines will be quite cold and the motor won't like that. Once running it'll be fine though.
Where do you live and how much is it per gallon and how common is it? I know of eight stations in my county now, double from a year ago.
Chiller449
Chiller449
I live in indiana near lake Michigan, It can get quite cold this time of year. E85 is pretty common around here. I would say atleast 25-30 stations have it within a 50 mile range. It costs around $1.85 a gallon. So you think the truck will run just fine on it even with 255k miles? Also how can i be sure i have the L59 motor? any marking i should look for on the block or something?
Your VIN and RPO code. The engine's look identical between the LM7 and L59 but you will have much larger fuel injectors and the rail might be different. I'm not familiar enough to tell. Also, yours has an alcohol content sensor and your original gas cap was yellow. If you have a good scan tool or fancy OBD adapter, you can view the alcohol content whereas a regular truck will not have that feature.
Chiller449
Chiller449
Where can I find my RPO codes? Are they still in the glovebox like they were back in the day? My gas cap is currently black but i have no idea if its original or not.
Yes, should be inside the glovebox door. If the sticker is gone, you can get it from GM in a chat session or email. They'll send the whole breakdown.
Chiller449
Chiller449
Found the RPO codes. It does say L59 on it. If I calculated right to break even E85 would have to be about 27 cents cheaper than Regular. This assumes im getting an average of 15mpg on gas and 13 on E85. I might try it if gas gets high in my area again. Currently they are pretty close. E85 is only about 15 cents cheaper.
I see about 3 MPG less burning E85 compared with 93 octane gasoline on average. It costs about $.04 less per mile to use E85 than 93 octane over the last thirteen months. The current spread is even greater as E85 around here has fallen in price a little more than gasoline.
With fuel prices always fluid, pun intended, E85 is not always the best value but the motor loves it, drives different and makes more horsepower and torque.
Big Mama
Virginia
Chris, do tell about E85 it’s seems I had it all wrong. In VA our pump gas had up to 10% ethanol and it’s awful for boats. I do run pump gas for the first few months of boating bc I’ll burn it up but at the end I use ethanol free and stabilizer. Engine is late 80’s model 5.7 marine engine. Is it bc carburetors?
Chiller449
Chiller449
Thanks for the info! ill give it a shot and see how i like it.
09 L9H
not a boomer
Upstate SC
I have run a few consecutive tanks of E85 through my Tahoe and honestly can't tell a difference between E85 and premium when it comes to performance. The greatly decreased range is why I don't run it anymore. My best MPG on E85 is 14 hwy compared to 16.5 hwy on 93. On a long road trip, that translates to a 65-mile decrease in range over a 26-gallon tank. Not incredibly significant, but also not trivial. Just something to consider. On a slightly related note, I filled up last night with 91-oct E0 fuel at $2.75/gal. Want to see if there's any increase in MPG over a few tanks.
Chiller449
Chiller449
I have run a few consecutive tanks of E85 through my Tahoe and honestly can't tell a difference between E85 and premium when it comes to performance. The greatly decreased range is why I don't run it anymore. My best MPG on E85 is 14 hwy compared to 16.5 hwy on 93. On a long road trip, that translates to a 65-mile decrease in range over a 26-gallon tank. Not incredibly significant, but also not trivial. Just something to consider. On a slightly related note, I filled up last night with 91-oct E0 fuel at $2.75/gal. Very excited to see if there's any increase in MPG over a few tanks.
Just curious why your running 93. Better fuel economy? better power? What price does it have to be to break even with 87.
09 L9H
not a boomer
Upstate SC
Haven't done a CPM calculation cause I'm mainly concerned with range right now. Gas is so cheap now (especially in SC) that I'm not really too concerned about the cost. Running 93 cause there are only 3 grades readily available where I am: 87, 89, and 93. Owner's manual recommends 91 (yeah, I know that doesn't really matter) and only grade that meets that requirement is premium. I did run 87 when I first bought my truck back in June and I have seen an uptick in fuel economy since then, but I think a lot of that has been right foot discipline. Also I had been running in 4 auto until about a month and a half ago.
TL;DR I don't want to have to worry about knock and gas is cheap
Chiller449
Chiller449
Mine is also always in 4auto. I thought thats where it was suppossed to stay. Do you get better mileage with it off? When i hit the top button it says stabilitrack disabled. I thought i was suppossed to be driving around in that mode but i didnt wanna damage anything.
It'll never knock on E85! Why do you not make use of the 6-speed?
Scottydoggs
NJ
if i had e85 here its all id be running. its free HP really, and kills any knock you might have. its got a lot more octane.
i just run 93 in everything.
Scottydoggs
NJ
ive never touched th eauto button in mine. ir rather it just be rwd.
mpg could suffer a bit, but in the end we are still turning the axle full time, just a bit of parasitic power loss.
Have you checked Gas Buddy recently for E85 stations? Seems every month or so around here another station starts carrying it. Our little county of 275K residents is up to 8 or 9 stations with it now. Last year it was half that.
Scottydoggs
NJ
i live in NJ, theres not one station that sells e85. pretty dumb being Long Island is full of corn and it has to travel through NJ to get to LI lol
Wylie_Tahoe
Corn is making whiskey, not gasoline. I dont want any more in my tank, then Gov-Co makes me.
Durobans
