shock length for 3/5 drop
thor1125
orange county
how long of shock should be installed on a 3/5 drop on the rear? extended length? also do i need to also install shock extenders or will shorter shocks do the trick ..? thanks .. also any info on what shocks with a djm 3/5 kit work best on the rear with part numbers or whatever? thanks again
NORCAL SS
SUV SUSPENSION GURU
do you have the djm kit allready?
are you using the rear djm blue coil? or gray coil since they are different lengths.
I have the djm front/rear shocks here for $190 shipped and ill beat anyones prices but in rear I need to know if your running the blue short coil and if you have the rear djm 5 inch kit it comes with trailing arms and swaybar endlinks and shock extenders are not needed.
thor1125
thor1125
orange county
i have the djm 3/5 kit .. it has the blue coil in the rear.. what is the grey coil? i do have the rear hardware kit and everything... so what size shock extended do i need to run ? thanks
NORCAL SS
SUV SUSPENSION GURU
The light grey is 3 inch. the dark grey is the hd springs that ride very very stiff. the silver ones i sell are the 5.5 springs that ride better and sit lower than what you have now.
You will need the djm 1800 shocks. I have them here and 85 for 2 shipped if you see it for less I'll beat it.
also lifetime warranty on shocks. If yours go bad i sent you out replacements no questions asked.
JPeter
