optimusprime
- Joined
- Jul 15, 2016
- Posts
- 128
- Reaction score
- 43
Also, maybe to narrow it down, it is most pronounced when coasting and then giving it throttle. There is always an audible clunk but it gets louder with greater speeds
My biggest concern here is that since you had no idea of what this process was, I am worried about telling you to crawl under the running rig and torque it in gear.
some light clunk noise is normal, you may notice it more if you park on a slight incline.Thanks for the info. I’ll check the slip yoke too. For what it’s worth, when I shift the truck in reverse and drive, there is an Audible clunk coming from under the truck. Been doing that since 2016.
I have the exact same thing in my ‘07 Denali and my motor mounts are new. But I do have a bad front differential mount that I’ve been too lazy to change, and a ton of slop in my transfer case chain. My u-joints are solid, so it’s possible it’s either the front differential mount or the transfer case in both of our trucks.Also, maybe to narrow it down, it is most pronounced when coasting and then giving it throttle. There is always an audible clunk but it gets louder with greater speeds
