see anything wrong?
Ceejkay
Ft. Lauderdale, FL
So my check engine light burnt out so periodically i do an obd scan. since replacing the motor ive had an O2 sensor code that i havent gotten around to replacing. well i started up the truck today with the scanner and now no o2 sensor. The reason for the scan today is yesterday i was at a light for a good little bit and the light turned green and the truck fell on its face for about 3 seconds and then was normal. My brake booster is bad in my truck (makes a hissing noise like air brakes) could that be why i had that problem? Motor has 4k on it atm. FYI this is first start of the day and less than 5 mins of running.
Ceejkay
Ceejkay
Ft. Lauderdale, FL
cool thanks, figured it looked good just want to check to see if the values were ok. im planning on getting the booster here shortly
VicYukon
Stockton, ca
The problem with your truck falling on your face it is because your breaks you'll have to replace the break pump I replaced mine about 8 months ago what I would do was put the ebreak once I would come to a stop on the light.
johnsonwillie199
