Rusty Frame
Kramlik
IL
I Was Looking At The Frame And Its Rusty, Not Horrible But Enough To Bother Me. Some Spots Worse Than Others... I'm Thinking About Just Using Whatever Tools I Have To Grind The Rust Off The Best I Can.
I Will Not Be Removing The Body Or Anything Like That, So It Will Be Me Under The Truck Getting What I Can... If Anyone Has Any Other Ideas About Getting The Rust I'm Listening :)
My Main Question Is What Should I Do When That Process Is Finished ? What Would You Guys Use To Protect It Once The Rust Is Removed ??
The More I think About It This Will Probably Be All For Nothing Since I Wont Be Able To Get To Every Spot And Get It 100% But I Have To Do It Anyway Will Look Better And Make Me Feel better
Thanks Guys
Kramlik
Kramlik
IL
I See a Few Youtube Videos Of People Using Chassis Saver Might Just Use This Stuff
From What I Understand They Dont Want You To Grind Off The Rust To Bare Metal
Just Use A Wire Brush And Get Any Loose Rust then Brush The Chassis Saver On
Anybody Use This Stuff before ?
What Was Your Process In Doing It ?
vsaravia
