Routin power wire....
txsmainevent
"The Lurker"
Texas
Hopefully this hasnt been discussed although i know it was in the new model chevy's, but this is the older model. I have a 02 LS, and am gonna put a 2nd battery on the passanger side under the hood. Im running 0 Gauge from the 2nd battery to my monoblock amp. I want to run 4 gauge from the primary battery to my 4 channel amp. Where is a good place for the 4 gauge on the driver side, and place for the 0 gauge on passanger side? or should i just drill the holes? if i drill i will go to the audio shop and buy grommets but just gettin some input....thanks for the help.....
groundscr8pr
flaccid member
scarborough maine
on the d side you can drill below the cruise control box. or use the giant rubber grommet further down. have never gone through pass side. sorry no help there.
T
txsmainevent
"The Lurker"
Texas
Hey Riff Raff, did you use insulation? Im doing a amp rack underneath the rear seats. Did you have to drill a hole to bring the wire up from the bottom or did you use a hole that was previously there? Appreciate the help!!
Riff Raff
Arlington,Tx
No insulation,and yes I drilled holes under the rear drivers side seat to the amp rack
joes 00 Hoe
Fallz Town, TX.
I did the same as RIF RAF.....ran it down the frame, and up into the floorboard on drivers side. I just posted some pics in my photo album.
vsaravia
