Riordan
- Joined
- Feb 15, 2021
- Posts
- 22
- Reaction score
- 2
2009 Yukon 5.3 Fuel Flex
After installing a spectre intake my vehicle now runs lean and gives me difficulty starting occasionally. Before installing I a new flowmaster true dual put on and had no issues with only the exhaust. Sometimes throws lean codes P0171 and P0174 but typically at idle or under load, I had the engine light on just a couple days ago and it went away while driving. Even though the light is gone my fuel trim is still definitely out of whack by looking at it using my OBD2 scanner. I've replaced numerous parts including spark plugs, wires, coils, fuel pump and the MAF sensor, 240,000 miles, the fuel filter is in the fuel pump which was replaced. It's happened ever since it has had the intake installed, it has also been smoke tested for vacuum leaks and none were found.
