Rooftop Paint
smcnair
Welp, finally happened. Washed the boy's yukon the other day and the roof paint is peeling off. Is it worth redoing the entire truck or just do the roof? Probably only going to keep this truck until he graduates in two years.
Big Mama
Virginia
What year and model? I’m a proponent of spending some on the truck you know well and has no payment. If you’re keeping it long term go ahead and paint the whole thing and fix body work. You’ll be happier in the long run IMO
Big Mama
Virginia
Ok reset then. It’s going to cost a lot to paint just the roof can you keep it between the roof rails or does the part above the windshield need it? If it’s just to get by and prevent rust I’d tackle it myself.
S
smcnair
I think I'll do the prep work then take it to someone to paint. Still want it to look good just hate putting money into it for cosmetics.
Big Mama
Virginia
Yeah that’s a good call. There are lots of options though for doing it yourself. Is it that visible?
Big Mama
Virginia
give it a try. They may not warranty any work they don’t prep but maybe a smaller shop that understands your situation they’ll make it reasonable. Ask what they’d charge both ways you never know.
mountie
A shop, spraying a top surface ( especially roof, you need a ladder to see well)....
Should not be an expensive estimate.
The roof takes a beating from elements...... A good coat of properly applied paint is very important!!
petethepug
Michael
SoCal
On our 08, the roof paint went at 2018 and the hood followed about 6 months later. Our go to shop of 20+ years gave a quote of $600 for the roof and $350 for the hood using PPG.
We attempted to just spray clear the 1st time. It turned out ghetto. The total respray on the hood made the truck pop again. We’re waiting to do the roof. If your going to sell in a few years, the cost of a good respray can easily be recovered as well as the reason a seller picks ur truck over a better deal w/ crispy paint.
mountie
Exactly.......
( shop quote)...... A lot of the dollar amount is the normal charge for the primer/paint..... That stuff is not cheap.
Conedaddy
