roof rack delete
Narco
Atlanta
Ok, I finally took mine off. Black Denali...you happy? NO PICS YET! What I did was get some 6mm set screws from home depot and some black body trim fasteners from oreillys. the problem is the body trim faster doesnt completely cover the brass fitting that the screw go in to. it looks a little better but i need a plastic fastener to go in the hole and come all the way down to the roof. does that make sense?
Narco
Narco
Atlanta
anyone got any ideas? know of any body trim pins that work to cover the hole entirely?
Young28
The Yukon God
ga
see if you can get some screws that fit flush and silicon those then maybe paint to match?
I have heard people doing that iirc.
scott99zx6r
Maricopa, AZ
I did the same thing but the ones I used are flat in the center then come down and cover the whole insert. Just gotta paint them white and I'm done. No pics right now.
Narco
Narco
Atlanta
i guess i could use the original screws...i like the plastic cap idea but cant find one that has enough of an "umbrella" head to cover the whole fitting
thehoe92
fo sho
The916
original screws are too long.. don't even try to put them back in its just a tease you get all the way down and then there is just a little bit left.
I used set screws and put them down in the hole a couple cm's then took a bottle of touch up paint and dripped it in to form a puddle of paint.. did all of them and came back and did probably 2 more rounds to get it smooth looking.
best part is its now sealed and matches the roof :)
Narco
Narco
Atlanta
i figured you would be. but i still cant find the right plastic pins!! do yours come all the way down to the roof line and completely cover the bolt face?
Narco
Narco
Atlanta
BD, where are youuuuu??? can you post some pics of your roof rack delete? some up close ones of the black buttons?
BlackDenali
Roof Rack ****
Boca Raton, Florida
Sorry man...My covers only cover the top of the brass fitting. I siliconed them in place to ensure a tight fit. If you look you can still see the sides of the holes but thats not a big deal to me. If your looking to completely cover the holes I suggest painting them black and them putting the caps I have in there to keep water out....Depends on how bad they bother you :shrug: Couldn't be as bad as the roof rack bothers me though ;)
Narco
Narco
Atlanta
but it ALMOSt bothers me as much! im gonna paint them black and then do the set screws/caps
chrias
Toronto, Ontario, Canada
Go buy some 1" body side molding that closely matches the molding on the roof. That's what I used. You have to chamfer the molding where the screws are so the molding will sit flush. That's what I did on my Suburban. Now I don't have to look at the unsightly bolts.
---------- Post added at 05:09 PM ---------- Previous post was at 04:49 PM ----------
Check out this "how to" thread by YNOT
http://www.tahoeyukonforum.com/forum/showthread.php?t=1454
Narco
Narco
Atlanta
yeah but i didnt wanna have to do all that. if it really bothers me i might consdider it. thanks though. good write up.
vtxtexan
