Rhino Line frame?
T-Bagg
The Esca-Hoe driver.
Doesn't Matter
I'm in the process of painting the frame. Right now getting rid of/treating rust grime and dirt. But before I commit and put brush to frame.
What do you guys think of using bed liner(Rhino, Herculiner) to cover the frame?
Mainly the visible outside and the bottom where it can get beat up by rocks and off-road abuse. I figure bed liner should be one of my most durable options. And I think I'll just do regular paint for the top, inside and the nooks and crannies.
vjr021
Clearwater, FL
I'm a huge fan of bedliner... I use it everywhere on everything... Tools, trailers... stuff is awesome..
grnrpr68
Davenport IA
agree i use it alot on my trucks cars etc too..work works alot better then paint on a daily driver truck
Brandon X
Michigan
I Herculined my entire undercarriage. It really helps protect from rust and I live in Michigan so I need all the protection I can get. I recommend it for sure.
bowtiefreak
No Quarter
Near Philly
I've heard it done and people say they like it. I brush on some thick semi-gloss black once a year and that works for me
T-Bagg
T-Bagg
Doesn't Matter
Then I guess the vote is in. I'll go pick up some Herculiner at AutoZone.
riviera rider
i used rubberized undercoat, not exactly the same as herculiner but im going to redo mine because i didnt clean it up enough so i may hurculiner it
puckhead
CO
They make any of this stuff in a spray can or is it all roll on type stuff?
puckhead
CO
Thanks bud, might have to check it out next time im at the store
Brandon X
Michigan
NP. It's about a $80-100 job whatever way you go about it, if you wanna do it right. I got lucky and got the whole Herculiner kit on sale for $70, then I bought 3 cans of Rustoleom to hit those spots you can't get with a roller or brush.
riviera rider
ya i can get a case (12) of the rubberized undercoat (rattle cans) for like 36$ :) should do the trick for me just gotta get under there and clean and scuff it up first
TheBigler
Mobile, Alabama
yeah i was thinking about doing this what should i use for my prep work down there cause i got dried up dirt and clay every where. you guys think i should just get at with a chisel?
Brandon X
Michigan
For my prep work I power washed everything real good underneath to get all the dirt and stuff and then I sanded all the rust off as good as I could. You should have seen the pile of dirt and rust when I was done, it was huge.
Wow that's a GREAT deal. You're so lucky it seems like you get good ass deals on everything lol. 12 cans should be perfect too.
T-Bagg
T-Bagg
Doesn't Matter
On base we have an auto skills shop with a lift and 3,000 PSI pressure washer. 3,000PSI hot water is how I got mine. For what I couldn't reach with water I used a rust and paint stripper on a drill. Worked well for the dried on stuff I had.
riviera rider
im planning on pressure washing mine then paying my little mexican helper to go over it all with a wire brush so all i have to do is mask off my fresh paint then spray that shit on :)
and we got a lift at work so shouldnt be to hard :)
T-Bagg
T-Bagg
Doesn't Matter
i'm jealous of the guys with access to a lift.
Ya should be jealous. Here on base we have a auto skills shop where we can do our own work. With something like 48 spots a third of them with lifts. Electrical and air hook ups at each. And all the tools you could ever need, minus welders. And ASE certified staff to advise us or provide a second set of hands. Parts supplier, gas station, auto audio/electronics store, and a service garage across the street. It's my favorite corner of the base.
bon jenson
i never thought to line it with that stuff. but i also redid my frame due to rust and just looked crappy. and i went out looking for paint. and found this stuff that you can either spray on if you have a gun. or brush on. it protects from rust grime whatever. and it looks good too. it says it can be hit with hammer or what ever and it wont chip or scratch. i mean i havn't really done anything major with it that would chipp or scratch it. but i have hit it with hammer and it did what it said. it's called "por 15" it comes in a few colors. but it is a really big process cause you have to either sand blast or grind your frame to bare metal. then spray this acid stuff on it. wait 20 minutes spray it again wait twenty minutes. then wippe down with paint thiner. wait awhile then spray just plain water and make sure all of the stuff is off. do that afew times. by then youve already done an hour. then you have to brush the stuff on. and the paint takes three hours to dry. not to mention 3 coats.
soo. it is very timely.
lemme know what the stuff you were gonna use looks like when done.
JeffK
