Reverse Lights
RydnDrty
Houston, TX
I have done a search on here for some good LED reverse lights, and all the ones that people have recommended are sold out or no longer available. Can someone please point me in the right direction. I am looking for some bright
6k LED reverse lights....I know HID would be better, but looking to just stick with LED for now....
Thanks
09tahoehybrid
Ohio
Thanks
I have been using the smd led's I got from ebay for almost 2 years in my benz e350, and for 3 months so far in the tahoe. No problems to report. I found sites like V-Leds way overpriced.
Gzes
the drifting 2dr
Wichita tx
What I do is just eBay them. Some members on here like to buy from superbright leds but its just a waste of cash really.... All my Libya are eBay and they still kickin and look great. I'm about to make custom parking lights and eBay is where I'm getting the smds.
NathanJax
Vacation Nathan
Jax, Fl
Autbond
Look to spend about $35 a pair on eBay and that usually will get you a good set. Definitely don't spend less than that.
Pain@thepump
sOuL-CaL
I was reading about this topic myself. I've had success w/ my hondas and LEDs from autolumination.com also. However to make them "last", I'm not sure, because reverse lights aren't used as often, they make this led load protector.
Common causes of Premature LED Failure
Switching on the ignition & starting the engine while the leds are switched on.
Changing or disconnecting the battery while the leds are switched on.
Charging the battery with an auxiliary battery charger, or revving the engine hard with a weak or dead battery while the leds are switched on.
Using jumper cables while the leds switched on.
Excessive AC voltage due to damaged diodes in the alternator.
High system or circuit voltage.
Voltage surges caused from switching on and off amplifiers or other peripheral add on devices that use a lot of power.
Faulty or out-of spec. voltage regulators.
http://autolumination.com/equalizers.htm
RydnDrty
RydnDrty
Houston, TX
You wouldnt kno any of the sellers names that you guys bought from on ebay?
Gzes
the drifting 2dr
Wichita tx
I just choose the cheapest ones from America and yea they last me good...
RydnDrty
RydnDrty
Houston, TX
will do...they should be in along with my black G4's and Bermuda Black IPCW 3rd brake light when I get in from offshore....
juggjiggler69
Try JLC AUTOMOTIVE i got these and they r super bright 6000k hid led lights
Sent from my Galaxy Nexus using Xparent Blue Tapatalk
juggjiggler69
www. jlclighting s.com here is there web site
JeffK
