Reverse lights cause draw
Roadboy
Michigan
Hey everybody here's the thing. When I put it in reverse the lights don't come on and the amp gauge reads 9 or real close to red. They worked a week ago and now kaboom nothing. I checked the fuse and removed the bulbs just to be safe but i'm not sure where I should start. The trans? The rear section of wiring? Thanks in advance
SunlitComet
OBS Jedi-Do Good
unknown at this time.
you can start from the rear bulbs and work you way forward thru the harnesses till you find voltage. at that point you would have crossed the fault.
---------- Post added at 04:48 PM ---------- Previous post was at 04:47 PM ----------
it does sound like it is the switch body or down stream if it only happens when in reverse.
Roadboy
Roadboy
Michigan
Yeah, only in reverse. I saw a thread that mentioned the circuit board in the tail lights. Is it common for that to short out or does it just go bad and nothing works? I'm going to get a dvm later today so I can finally get some useful info. Thanks for the help SunlitComet
briannorris
