Retained Accessory Power or 12 volt accessory help!
stevek
Dallas, TX
No compass fuse, I do have a compass, but it is in the DIC. Not sure what an RSE fuse is, will have to check on that one. I have it hooked up now so that I would have turn the key all the way forward before starting the vehicle to get the headrest monitors to play. Still looking for a fuse that let me turn the key just once to get it to turn on.
I had surgery today, so I can't really walk outside to 09 because I believe that the 09 has the same fusebox as the 10. If someone can find an online list of the fuses in that fusebox, I can help you out.
BabyHuey
Bellevue, Nebraska
You could also find teh accessory wire in the ignition harness. The gm geniuses didnt feel liek they wanted to put one at the radio. Fools.....
johnsonwillie199
