Replacing lower intake gaskset
raptorforme93
Tampa, Fl
As some of you may know, it has been determined that my lower intake gasket has gone bad and needs to be replaced. My truck will be towed home from where I live at FSU 3 hours north. Over the Christmas break I will be replacing the gasket in the garage. This is my first time digging into this engine and I was wondering what all I am going to need to do this job? I know that a lot of people have done this and a little imput is appreciated! I want to be ready to fix the hoe when I get home! Am I going to need any special tools? Will this be a good time to replace some other commonly worn out parts? Any other fluids I should change besides the oil and coolant while im at it? I want to be as prepared as I can be before I start the project around Dec. 22nd I think. I will also be taking pics of the whole thing for everyone!! Thank you :)
ezdaar
Chat Troll
Redneck central, Aka Houston
its gravy work bud.
Only diffacult part you may have is re timing the engine. but thats easy aswell.
I can walk you through the entire procedure if you want.
How did you determine it was for sure this and not head gasket?
ChrisAU
Birmingham, AL
Get a razor scraper. Also figure out a way to keep the manifold bolts organized; for me, I drew out the bolt pattern on a piece of paper and numbered them, then gave each bolt its own numbered baggy.
willxfs
Maybe valve cover gaskets while you have everything on top apart.
ChrisAU
Birmingham, AL
Oh and here is a biggie, tap the holes in the block and run the bolts through a die (the proper sizes of course), this cleans and sharpens the threads so you can get a proper torque reading when you are putting it back together. It doesn't take a long and its easy, on my '92 I was able to turn the bolts through the die by hand, and once I got the tap started in the holes in the block I just used an adjustable wrench to turn it. If you have a lot of resistance to your tap on the holes in the block, stop. You do NOT want to cross the threads of those holes with the tap.
raptorforme93
raptorforme93
Tampa, Fl
@07burb: Based on what everyone said and how much more common it is for the lower intake gasket to go out. My truck still runs perfectly with no noticable difference in sound, idle, starting, and whatnot. But I have no definite proof I guess. Doesnt all this stuff have to be taken off and apart if it is a head gasket anyways?
Ok thanks for the note on bolts. I will make sure to keep them organized well and ill take a look at the bolts from the block and the holes to see about retapping them. That would be a good idea if done right. Haha. One other thing, over the last few months, my hoe has slowly but surely developed a slight tick that is coming from the driver side of the block it sounds like. Basically I just want to reassure that the valves are within spec clearances. I figured that this would be a good time to do this? I am only really familiar with adjusting valves on race fourwheeler engines...
992dr
Eastern N.C.
Is it leaking any fluids? Oil or coolant?
Mine started leaking coolant, not only did it leave stains everywhere I parked, it also could be trasted to the exact spot from the coolant stain on the block.
While you're in there you should replace your spider assembly with this replacement assembly. http://www.amazon.com/Delphi-FJ10566-Fuel-Injector/dp/B000TYLIFS?tag=vig-20
You should consider using Felpro gaskets, only the best for our Hoes ;)
Also give the RTV the respected amount of time to set before putting the manifold back on OR you could be doing this all over again.
Another way of keeping track of nuts,bolts, studs is by taking some pictures of how and where each nut, bolt, stud goes. Some have one and some have two nuts some have brackets some dont. It would also help with your a/c lines. I effed up and its driving me nuts. But I have to go back and replace my spider assembly so I'll fix that when I do it again.
ezdaar
Chat Troll
Baggies are a no go, Chemicals on the bolts and your hands will eat up the baggies.
Use the cardboard from your gasket kit, draw the bolt pattern on it, punch holes where bolts go with Phillips screwdriver and mashem through.
If needed write on the CB what that bolt set is for and a arrow showing front of engine. They wont fall out and there's NO guess work as top where they go and a big ass piece of cardboard is not easily lost.
always remember this tip. Every bolt regardless of its length when inserted into the holes BEFORE threading, will all stick out equally. If one sticks out farther then the rest its in the wrong spot OR there's a bracket that goes under it that's missing.
Dont waste time tapping the holes, unless a bolt comes out RUSTY and all nasty looking. Just clean them out with B-12 and air compressor dry them.
Wire brush or wheel your bolts reapply RTV and your good. no need to replace them, they are under no significant stress.
ChrisAU
Birmingham, AL
If you don't tap the holes, you're not going to get a good torque reading...
And what chemicals are you using that melt through zip-loc bags? More importantly, why are you leaving that chemical on the bolts? I supposed a cardboard box is going to stop those chemicals?
raptorforme93
raptorforme93
Tampa, Fl
Ok so Ill be towing the hoe home on Wednesday and will get to work on it Thursday or Friday. What will I need to get for the materials when I run to Napa? Will Napa have new bolts that I can pick up or will I have to special order them?
SeriousSide97
yea replace ur bolts, get new valce cover and lower gasket. get head gaskets too hell. I wouldnt tap em , but Id put new bolts in and problaly paint your valve covers when u take em off. I did
ChrisAU
Birmingham, AL
As for the bolts they should all be the same, though on my TBI they are all different lengths so I reused the old ones and ran them through a die.
A tap doesn't cost more than $5-$8 and takes maybe a minute per hole to do, and properly torquing the bolts down is an integral part of the durability and effectiveness of the new gasket. You aren't tapping new holes in bare metal, you are simply using the tap to scrape out the muck and old thread sealant so that your new bolts will get a true torque reading.
gmcconvert
so what ever happened? did you fix it? i just did mine so was wondering how it went. cylinder head gaskets too.
raptorforme93
raptorforme93
Tampa, Fl
Ok sorry guys it's been a while. My Christmas break ended up being really crazy and I only had time to partially take apart the engine. Now I am back home through Monday evening and I plan on finishing my truck. As of right now it is completely apart and the gasket is broken right where the guide said it would be, so yes it's definitely the lower intake gasket that failed. The whole valve channels and insides are a mess from all the coolant. Lots of cleaning up to do tomorrow. Haha. So basically I am working on my truck all day tomorrow and I have a few questions.
1. What is the best way to clean up the gasket surfaces beyond a razor scraper? Should I buy any solvents or anything? I am going to lowes tomorrow to buy tools so any suggestions are great.
2. I marked the distributor to help realign it, but how do I go about resetting the cam timing when everything is done? The guide said that you can't use a timing light on these trucks and it has to be done with a scanner? Is this something I can do or should I have a shop do this? Also, will the truck be drivable at all without immidiately retiming it?
The new gaskets are felpro also which is nice. One last thing is how long do I have to let the new sealant sit and cure before the truck can be started? Thank you!
raptorforme93
raptorforme93
Tampa, Fl
Well none of my questions got answered, but despite you lazy bastards I still got the hoe all put back together and running right :) I spent about 20 hours doing the whole thing in our little tiny ass garage, but it was not problem since I went slow and took a few pictures of the layout. I have never torn into this engine at all, or any other V8 engine for that matter. I learned a ton and I bet I could do it again in less than half the time. I drove up to Tallahassee last night and it was perfect! I honestly think that she runs a little better and smoother now :)
raptorforme93
raptorforme93
Tampa, Fl
It's ok man :) Haha. I still got it done! My question now is how do I have the cam timing set? Do I have to have it reset? I have been driving it and it seems like it runs perfect, but I know I may still have to have it done
briannorris
