Removing factory running boards help.
DefendHawaii
Snake Eater
Kahala HI/ Seattle WA
I got a wrecked Tahoe with
Intact factory boards. It's down at a local yard but I got limited to tomorrow to go down and remove so what
Tools do I need to pull them off real quick I got a few interior parts I gotta get too. How easy is removal? Are they real heavy? It's on a 2002 Tahoe.
Mr.Jack
Norway
They are not heavy at all. Takes a little time though, because there are quite many bolts that needs to be removed.
electro
Kitchener, ON, CAN
A nice thin slot screwdriver will help you open up the rear hvac straps.
They run over some of the bolts.
You just push the slot screwdriver into the middle pry out a little bit and push up.
moto
