Relocate Gas Tank
OrangeTahoeSS
San Francisco, CA
First Tahoe I See With Gas Tank Back There....
Anybody Know Anything About This?
Monstar_est87
City of Angeles
U'll have 2 remove ur spare tire gear underneath in the rear and ull need longer fuel lines, reroute or fab up a fuel neck, and extend the electrical wires for the fuel pump... And then ull have 2 mount some custom fuel tank strap retainers to hold it in place... Not impossible, but its only like a 12 or 15 gallon tank... If ur looking to reduce weight and balance out.ur ride this would be the way 2 go...
O
OrangeTahoeSS
San Francisco, CA
Perfect, Thanks Man! :D & Yes, That's Exactly What I Want To Do. Also Build A Nice Dual Exhaust! :thumbup:
Sent from my GT-P5113 using Tapatalk 2
Gzes
the drifting 2dr
Wichita tx
Jist remember that the guard for the tank in the 2dr is heavy and sucks to remove or intsall.. yoy also have to relocate the filler to the back. Why not run dual tanks like a truck? Have a switch to change pumps
O
OrangeTahoeSS
San Francisco, CA
A Friend If Mine Owns A Fabrication Shop, Could Probably Make Our Own Cover.... Relocate The Fuel Filter?? Does It Have To Be A Certain Distance.. If I Were Not Building It As A Performance Truck That Would Be A Great Idea. But To Much Weight.
Monstar_est87
City of Angeles
Not sure if its all burbs or sum... But I have seen a few with a rear tank... Not sure if they have both... Might b worth looking into...
_Dylan_
STAY FROSTY
I wouldn't waste my time moving it. There are better ways to get a performance gain.
You could just drive it with a 1/4 tank if you want to save weight at the drag strip or whatever.
Gzes
the drifting 2dr
Wichita tx
I did mean filler like the filler necj where yoy put the gas in lol but if you run dual tanks then thatd be pretty cool but still would need to pop a new hole for gas to go in
_Dylan_
STAY FROSTY
You can use the same fuel door location. You just have to weld up a new pipe into a Y split right behind the cap, so you can fit the gas nozzle into either tank.
I try to find a picture tomorrow.
Gzes
the drifting 2dr
Wichita tx
I kinda know what dylan is saying but i like one on each side like my 1 ton tow truck has
O
OrangeTahoeSS
San Francisco, CA
The License Plate One Would Be Cool! .... I Kinda Like How The Tank Looks In The Middle.. It'll Balance The Car Out More.. & I Don't Like The Way Both Exhaust Tubes Have To Be On One Side. I Want To Have A Dual Exhaust 1 Out Of Each Side Infront Of The Rear Wheels... :D
Sent from my HTC_Amaze_4G using Tapatalk 2
foreverfalcon40
That is what I always wanted, but instead for less of a headache going to copy a NBS style here that his exhaust tips before rear wheel on a the driver's side with a Z-28 exhuast tip. **** and low clearence for us lowered folks!
lfh2indiana
