Regency remington cluster over lay with my denali cluster??? Help???
1lowhoe04
Fort Worth Texas
HERE MY DENALI CLUSTER
NOW I HAVE THIS OVER LAY FROM REGENCY CLUSTER OVER LAY WILL IT WORK AND HOW TO DO IT NEED HELP YOU GUYS
Oklahoma
Looks like it should work. Pull you dash cover off. There is 4 screws holding the cluster into place. Unplug the harness. There is a couple of tabs holding the clear plastic cover on your gauges. If I remember right that should be it for taking it apart. The trickie part is getting the needles off and back on correctly. Your gauges might have came with a needle remover if not the best method I have found is using two spoons and prying them up. The key is to get the needles off without moving them. Then they should just lay on top of your other gauges. You can pull the stock gauge face off. Just take a hair dryer heat it up and peel it off.
ThwopKing
Bunker Hill, WV
shouldnt have to peel the stock guage cover off..nor would you want to. Just lay that panel over your stock gauge..after you remove the needle of course..and just put all the needles back to zero when you put them on..that where they fall when you turn the truck off. The new overlay should have come with a tool to remove the needles.
edit...well i just noticed all the number layouts are different. Im used to the layouts being the same just different colors and what not....my bad
1lowhoe04
1lowhoe04
Fort Worth Texas
WELP HERE YOU GUYS GO DONE TOOK ME A MIN TO DO THE STOCK DENALI OVERLAY JUST CAME RIGHT OFF and regency went right on
Candielaine
