Reduced Engine Power, reducing my sanity
John Bragg
I'm curious is the reduced engine power the sign that the Yukon is ready for the yard??? I have been fighting this issue for probably pushing 2 years now. I have put in mass air flow sensor, throttle body, throttle position sensor, accelerator position sensor, new plugs, new wires, new fuel lines, new fuel pump, and lastly a crankshaft position sensor. Yet still same damn problem popping up. Will this madness ever end? What else could be causing this very irritating and frustrating problem? It's a solid great vehicle and without a doubt the best vehicle I have ever owned, just this one nagging issue that won't go away...is there any help that doesn't involve dropping huge amounts of cash to the "stealership" to get it right. Thanks in advance for any help and suggestions. It's very much appreciated
Do you have an advanced scan tool John? Without one, you're just throwing parts and guessing. Do you own the shop manual for this truck?
John Bragg
John Bragg
Unfortunately no I have a lower to midgrade scan tool, and no shop manual.
I think we've "talked" before but I do not remember your truck's particulars. You can get a subscription over at AllDataDIY for your truck or buy/download the manual from SeriousCTBuyer on ebay. I use both, sometimes one is easier for me to use than the other but they're kinda redundant as far as the information goes.
Can your tool read fuel trims and transmission speeds and the like? That might be enough to get by. What codes were you getting after seeing it say "Reduced Engine Power"?
John Bragg
John Bragg
The codes it popped up this morning in are P0120 P1515 and P2135. Considering they are all throttle related and I have replaced both the throttle body with sensor and the accelerator position sensor I have been thinking maybe I should replace the pig tail for the throttle body. I have inspected it in the past and done the pull test on it, it did however have some crazy bends and was all twisted and crazy right at the plug. When I did the pull test I removed each wire one by one untangled it from the mess inspected it and did the pull test then and reinstalled it back into the plug. So I am thinking maybe there is a wire with an issue in there since all the codes are related to that circuit. I will look into those suggestions you made information is power after all.
The codes it popped up this morning in are P0120 P1515 and P2135. ...I will look into those suggestions you made information is power after all.
Get your hands on that manual so you can do the circuit tests. Mine does not show the P1515 code but does show the others. Everything points to either bad wiring, bad ECM or bad TB.
John Bragg
John Bragg
That's what I was afraid of I'm also checking all the grounds some people I have read online had issues with that causing problems. I also have the ABS pump kicking on when stopping but only at less that 5 mph I would say and no light in the dash for that one. Thanks for your help I really appreciate it
Sent from my VS985 4G using Tapatalk
UrbanSuburban
I think the code that you seen was P1516, I would look after the P120 first as it gets fixed then the others will go away. Its that code that sets the reduced engine power. At least you are not getting the engine off command, as that is the next step in the diagnostic tree. If you have disconnected the TPS you will create some more codes which is probably what the other two are. There are 33 steps in the Diagnostic tree for this code. You need to get the Alldata for this as you are shooting in the dark. You have replaced two items on the list that give cause but still no solution. With Alldata you can buy only one month and that should give you some time to get to the bottom of it. Good Luck with it. As far as your ABS kicking on, that is a bad sensor in one of your wheel hubs, the truck thinks an abs event is happening so it does not activate a code. A scan tool will locate the problem side for you.
John Bragg
John Bragg
Awesome thank you for the info I appreciate it.
Mechanic421
06 Denali XL
Statesville North Carolina
I had a Rainer 5.3 I did a new throttle body and pigtail but had to redo pigtail because I did not soldier the connections the first time. I used heat shrink the first time and only lasted about six months. When I replace a sensor I almost always the pigtail if I can it is good insurance.
ncampion
You didn't mention when you are getting the reduced power event. On my 6.2 Denali I was seeing that and went through the replace all parts drill and still had the problem. Turns out it had low oil pressure when warm at idle. 113,000 miles and apparently some engines had accelerated cam bearing wear which caused a low oil pressure when hot situation and the ECU reduced power due to the low pressure. When cold or higher RPMs it was OK. New engine was the fix.
Schwartzint1
Ugh I was hoping to hop on here and see some magic fix. As the op I have also tried a number of fixes. New throttle body sensor at the dealer. New oem throttle body. New pedal sensor. Still getting codes like crazy. The dealer is a joke. Last time I brought it there they pulled it up to me with a check engine light on. That’s after they fixed it. My family mechanic has looked at it about eight times and says it’s not worth his time anymore. I’m thinking about taking it to one more shop, but after that it may get a for sale tag. Or set on fire ;) It’s a 2011 ssv Tahoe with the 5.3. I know your frustration.
John Bragg
John Bragg
If I could sell mine I would get rid of it and honestly go to something older and less computerized, nothing but a pain in the ass I love the vehicle as a whole probably ly one of the best I have ever owned but this issue and the headache and all the shit that has come along with it...I'm over it ugh
If you have a cheap scanner, just clear the code. It should be fine, that's what I've been doing lately.
John Bragg
John Bragg
I've been dealing with this issues for a year and a half. I have a gut feeling it might be the ECM. Another wierd thing I have noticed is the driver seat forward and backward control is backwards now. My setting are on driver 2 my wife's settings still operate normally. I am so over electronics give me mechanical any day that I understand and don't need anything special to fix.
I heard when the seat does that it's a bcm issue. I hear you about all the electronics, they are a pita.
Brisolle
I had the same problem with my 2004 GMC Yukon xl Denali. After spending beaucoup bucks replacing all of the above. I decided to clean (Unscrew the two ground wires that are on the frame right under the driver's side door (right where the split front the from front fender). I also unscrewed the ground wire behind the motor on the firewall. Problem fixed!!!
HeavyHoe03
