Rear wiper not working
jatPPV2012
Tampa
I don't really use the rear wiper when it rains, but I just noticed it does not work. The last time I remember it working was before I had my PPV repainted back in June. For the whole month, it was at the body shop and so I suspect something may have happened when they took off the wiper during the repaint process or when they put it back on after the repaint was completed. I checked the fuse box and the fuse is fine so I'm not sure where else to check. Has anyone had this type of issue before?
Appreciate any help or tips.
Thanks!
I'd check to see if you have 12 volts to the rear wiper motor, and a solid ground connection, when the rear wiper switch is turned on. If those measurements and inspections are good, then the wiper motor itself may be gone.
Other folks here can give you more specific instructions on how to remove the interior trim panel on the door, in order to gain access to the wiper motor.
26AT4
