Rear track bar replacement tips?
OneofFew
Talullah Falls, Ga
Hey guys. I am wondering what the easy way is to replace this thing. WHeels off the ground or just lift the body some?
diLucca
Bratislava, SLOVAKIA
I lift it by rear axle, and let it sit on stands. So you can crawl under car. Also torque bolts with weight on axle.
With QA1 rear panhard I have issue with narrow mounting point so i have to bend out them to fit it.
iddqd
San Francisco, Comifornia, USSA
I replaced mine just by dropping my spare wheel and driving up on the ramps just for ease. You'd need two 21mm wrenches. For the passenger side, you'd need to disconnect ur sway bar link (either from the sway bar itself or from the frame).
AdrienR
