rear spring tow question
ktmhans
Connecticut
My 04 lt sits pretty level with the front keys cranked a little. My question is dropping a trailer on there is going to throw me the other way. Whats the best option
Run Z71 spring
1" spacers
Bags inside the coils?
My 98 tahoe i put airbags on the axles. I loved it i could really load up the truck and it flattened the truck in corners too.
Whats the best thought
jplinville
Run Z71 spring
1" spacers
This is the reason why the rear sits higher than the front...so you can carry weight and tow evenly.
jplinville
Replace the shackles with one that give 1.5-2" lift...it will raise the back end back to the factory difference between front and rear. It will also give you the ability to tow without driving nose up.
The shackles shouldn't cost much...check Belltech
K
ktmhans
Connecticut
Shackles on a coil spring rear end?
BananaHANDS
Oklahoma
I had the same issue on my 03 z71 spent 80 bucks on some airlift bags and couldn't be happier. This way I can had as much air as I need for the amount of weight I'm pulling. It also reduces porpoising down the road with a heavy tongue weight.
K
ktmhans
Connecticut
Thats what i was looking for. In the coil they dont lift the rear end up right, they just hold it up.
Any chance u could throw up a link
The 'ER
Minnesnowta
Simple question... What kind of trailer? Camper? Utility trailer? flat bed with a lawn mower? I would stick to air bags if you do anything on the heavier side. Camper, utility trailer etc. Other component is how much tongue weight? I work at an RV dealership so this is what I do all day long. If you are going to be hauling a big trailer than bags and a weight distributing hitch. Smaller trailers or utility trailer then just bags. We sell firestone and we have had zero issues.
K
ktmhans
Connecticut
Little landscape trailer is no big deal. But we are also buying a dump trailer that should be in this week. We went with the smaller dump trailer. 10' model as to the 14'. Still a heavy unit@3100lbs empty. I know i wont be able yo pull it around with a full load but at least we wont be limited to pulling it with just the 2500 dodge.
Never thought of a weight distr hitch, bummer. I just picked up one of those cool alum, flip pin hitches. Ever other hitch i have doesnt work with this truck because its do low.
Vinniety
Westchester, New York
I have a 2002 z71 and i ended up adding the airlift bags in my dropped coils and i love it. Add a little air when i need it and that's it.
K
ktmhans
Connecticut
So just to confirm, the bags that go in the coils wont lift the rear up, just hold it. I would have to put in 1" spacers probly also.
JPeter
