Rear leveling with ZW7 package
brandon bunn
Hello I’m new to the group thanks for the add! We have a 2013 2wd tahoe with ZW7 and max tow to pull my race car. I’ve done a bunch of digging and didn’t find much on leveling the rear with ZW7 and not effecting towing.
With that said I want to level the rear so drop about 1.5-2” and not lift the front. I want to run Bilstiens in the front and so far the best thing I found was the mcgauphy’s rear leveling springs with the shock extensions but it DOES NOT have Nivomat shocks so I don’t want to mess up towing with a soft lowering spring
It currently has part number
22811850 springs in the rear (maybe HD? That would explain the hight)
22811844 rear shocks
What about the ppv spring and a Bilstien shock? Or will that ride harsh with that spring
What about a standard size LS spring?
am I on the right track? Is there a better way to do this safely and keep my towing capabilities?
thanks!!!
Drok
Cold place in the north
you could always get helper bags for towing with the drop springs. I cant really help ya on the zw7 system, just tossing out another option.
That’s basically what im gonna do, but i have regular shocks. (McGs rear drop and helper bags for towing)
brandon bunn
brandon bunn
I’m going to use a regular LS spring it will drop it an 1.5 inch and it’s the same spring rate as what I have
MonteJ
