Really need an answer
LOUDHOE
Seneca, South Carolina
I have an 04 tahoe and I did a 3 inch spacers in the rear 3 inch spindle up front and keys, and I had to completely decrank the keys to get the front close to the rear. That made the front really soft, I need more height in the rear so I can lift the front up to stiffen thefront and clear the tires better. My question is can I stack spacers or do one on top and bottom, or do some skyjackerlift lift coils. And if I do I haveto do any dropping of the track, panhard, or swaybar end links.
Thanks, Ben
WildBill
I wouldnt stack spacers. maybe the skyjacker lift springs would be good choice, or z71 coils are said to give an inch or 2. I would expect you to nee ad least a panhard relocation bracket(s). The rear may be pushed over quite a bit with 3-5 inches of lift. you may find one wheel rubs and the other stick out!
Good luck, post some pics.
brucebruce45
If u go any higher than 3"-4" on the rear the panhard bar will be too short and kick the right side out and pull the leftside in. U can order the 6" springs but will need to get the panhard bar drop bracket to go with it...I think I still have my 6" springs I could well u for cheap I'll check Tom
LOUDHOE
LOUDHOE
Brandon did you ever find out if you still had your 6 inch springs? Also do you know where I could get a panhard bar drop and sway bar end links?
Ben
PCB, FL
I honestly wouldnt even run those 3" spacers in the rear. I would get new coils out back.
LOUDHOE
LOUDHOE
I already put them in, I need to crank my keys up to clear the tires up front better, but the front is already 2 inches higher than the back. So the back had to go up.
brucebruce45
I'll check tomorrow on the springs. On the bracket I just ordered it from skyjacker. As for sway bar links, my dad had a 6" skyjacker kit on his 01 f250 and he didn't use his rear sway links. Come to find out they are a perfect fit for a Tahoe lifted 6-9" in the rear.
LOUDHOE
LOUDHOE
Is there anything that needs to be done to the four link to get the u joint angle on the drive shaft right or put the axle back in the center of the wheel well
brucebruce45
not just using the 6'' springs or just goin 6''. itll be pulled forward a bit but nothing too drastic. if u go any higher i would get the link drops aswell
dizhai
