rcx lift 4" OR 6"?
setty7
i have a 99 tahoe 4 door obs and I am looking at putting a suspension lift on it. Right now Im running aprox. 32's with about a 2" torsion crank and 2" rear blocks. I was looking at the rcx 4 or 6" lift. I know there isnt any difference except aal's for the back. I dont want to do aal's so ill probably just do 5" rear blocks and do 1" cranking to get 6" in the front. Has anyone used this lift and have pictures of it without a bl just straight up suspension?
Thanks,
Justin
Dpsthomas
I've been looking at the same lift. I'm pretty sure BowtieFreak has the 6" lift on his Tahoe. You can hardly view a post in the OBS section without seeing his red beauty. I'm probably going to get the 6" myself but I would prefer lift springs in the rear if I can find them.
S
setty7
Why lift springs? Doesnt that cut down on towing? Im just wondering also. Ive heard the rcx is just a 5" differential drop and either decrank for the 4" in the front or crank one inch for 6". Is that right?
Dpsthomas
I want lift springs because my stock springs seem to be worn out. I think you're correct about the lift. I've read that the 6" is the same as the 4" with an AAL.
bowtiefreak
No Quarter
Near Philly
RCX is a nice kit, I run it on my suburban. the difference from the 4 to 6" kit is nothing more than the AAL. The kit even came with the longer rubber front brake lines. The kit drops the differential down about 5.25". I have been very happy with the kit, been running it for a few months now. The tahoe runs a DC lift or extremem suspensions kit....a taller 6" lift.
Lift springs are great for the back but will stiffen the ride over using just a block. A block literally just lowers teh axle and doesn't effect ride quality like a new spring. I run 6" springs on the tahoe and teh ride is stiffer. With that all said big blocks are never a great idea but they serve a purpose.
If you have more questions let me know. here are a few pictures of the suburban set around 5.5" of front lift. it is running a 35x12.5x17.
S
setty7
Did you have any rub with those tires? What size are they? What about specs on the rims? Thanks man! Is there a way to just get 5" blocks with the kit?
bowtiefreak
No Quarter
Near Philly
the tires are 35x12.5x17 on a 17x8 ATX mojave with 4.5" BS. Yeah they rubbed a little so I trimmed the back part of the wheel well. I rub on the tahoe which is more than 3" taller. normal driving I do not rub on either though. not sure about a 5" block. I would not do that, use the AAL
TahoeTaz
Jersey
My 2 door has a 6" RCX lift, no body lift, and 35" tires. Tires do not rub on anything (other than the suspension during full lock). I'll take some more pics of it tomorrow.
992door
Greenville, NC
Ted the reason you have no problems other that hitting the suspensions is because of the stock wheel. Once you start going wider and less backspacing that is where your problems start to come into play
19Yukon97
Texas
im going wit h that same manufacturer of lift. im getting the 6 inch lift for just the ability to have 2 inches of lift more later on down the road. but the plan is to decrank to a 4 inch with 33's then crank later on if i want to...
bowtiefreak
No Quarter
Near Philly
mine dont rub under normal conditions....
So....my advice: RCX 6" kit, deal with the AAL for now.
S
setty7
ill probably do a 6" and crank up to 5.5-6? And do what in the rear? Im not sure if I should do 2" block and 2" springs? And probably an aprox 34x12.8x18. Will they rub with a -11 offset? Thanks for all the advice!
bowtiefreak
No Quarter
Near Philly
For the rear, 4" block and 2" AAL, comes with the 6" kit. tires shouldn't rub too bad, just trim as needed.
S
setty7
What if I dont want 6" in the rear? Wont 4" maybe 5" clear 35s or 34s?
bowtiefreak
No Quarter
Near Philly
No lift can clear 35s....as long as trimming and cutting is ok. But, yes 4" can clear it just not well. Why not run a 33 on 3-4" lift. Did you consider that running a 35" tire will require new gears also?? That will cost you close to $2K to have that done and that should include the front and rear gears, install kits and a true trac
S
setty7
yea man i did, can i clear 325/65/18 (34.75x13.5x18) with 5.5-6 in the front and 5 in the rear?
S
setty7
What about 5" in the front and 4" in the rear will it be able to clear 33x13.5x18?
96ProCompTahoe
IN
wheel backspace is going to be the real factor with that wide tires. what wheels are you running?
worleytrev93
