radiator fan wiring diagrams....
checohz_
hi.. My car has a fan clutch system and i want to replace it with a 2 separate single speed fans, I want to wire the new ones, in low speed when i turn on the a/ac, and the high speed to a temp. sensor that will signal the relays in hot temp. +185º...Is this Possible??
The car is a tahoe 2000 .... TKS
T3rry
Calgary, Alberta, Canada
just get the harness from blackbear, plugs in to your factory pcm and controls them as stock (you also have to get the pins activated.
Drewphil
