Question? Do I need spacers for 24" Wheels
williamsterry804
Hello Yukon-ers!!
I have 2021 Yukon Denali w/ magnetic ride control. I want to move to 24" OEM Replicas w/285 40 24 tires. One shop says I would need spacers. Many on Ebay that sell 24" wheels says I don't need spacers- like AudioCity & SouthCoast Wheels & Tires says I don't need spacers. Question: Anyone out there that has magnetic ride control and upgraded to 24" or 26" wheels - how is the ride compared to the stock 22" denali???
zbad55
Army
Detroit
If you can get the correct backspacing with the width of the tire taken into account you should not need spacers. Pretty easy to figure out when you have the specs of the tire and wheel.
Pics of the truck, please.
Regarding wheel/tire combinations that will fit your truck without rubbing, no 2 trucks and their suspensions are exactly alike, due to a number of factors including accumulated wear on the suspension components and different wheel widths and offsets, so there is no guarantee that what fits with no rubbing on one truck will automatically fit with no rubbing on your truck. Other folks' experiences can guide you in one direction or another, but the final test will be when you mount the wheel/tire combination on your own truck.
To assist you in getting a good idea on whether or not specific alternate wheel/tire combinations 'may' fit your truck with no rubbing, I recommend that you use the wheel/tire comparison app at the URL listed below. You can use this app starting with your existing wheel/tire combination as a benchmark, assuming that there are currently no rubbing issues with it, and measure the actual critical fender and suspension component clearances as directed by this app. Then, you can enter alternate wheel/tire combinations, and this app will give you the projected changes in these critical fender and suspension component clearances.
https://www.wheel-size.com/calc/
I used this app for determining whether on not I could use my current alternate wheel/tire combination, and it accurately projected the changes in critical clearances. Again, the use of this app in not an absolute guarantee that an alternate wheel/tire combination will fit without rubbing, but it provides a much better assessment, or projection, than simply an educated guess on your part, or a statement from others that it worked on a truck other than yours.
GMCChevy
If you're using factory rims with the proper tire sizes you don't need spacers. If you bout some random wheel and tire combination it's a gamble if they'll fit or not.
Charlie21ny
