Question about my barn doors
mranum
I contacted my local dealer yesterday about new pins and bushings for my '95 Tahoe rear cargo doors and after about 5 min. he comes back and says that they have been discontinued for the '95 & '96 models. Apparently the '97 and later were different?? He seemed genuinely stumped and didn't have any other options for me.
Now, if aftermarket houses don't have 'em and I can't get it from the dealer.....? Has anyone ever checked to see if the pins & bushings from a van are the same??
:think:
Donnie Yukonie
Yates Caretaker
I don't see how they would be different from that period of time I could be wrong . Have you tried LMC ?
M
mranum
Yeah I did, only side doors listed that I could see.
Donnie Yukonie
Yates Caretaker
No Problem , Most of the time they will add notes To the parts if they only Fit certain years I.E dash differences in 95-99 , I would give them a Call to be safe they will know
SunlitComet
OBS Jedi-Do Good
unknown at this time.
i will check with gm right now....
---------- Post added at 07:41 PM ---------- Previous post was at 07:25 PM ----------
just to be clear these are the barn door "hinge" hardware correct not the door catch mechanism? either way i got gm part numbers and source for them.
M
mranum
Pins and bushings for the "barn door" hinge.
SunlitComet
OBS Jedi-Do Good
http://www.genmotorinfo.com/Picture.../REAR+ W/ZW9 +-+CK 06-16 +&pid=961217TZC16-15
#69 bushing gm 15995442 $3.02 each
#63 & 70 pin gm 15645336 $2.80 each
gmpartsgiant.com just enter the part numbers where asked. also there application is 92-95
---------- Post added at 08:33 PM ---------- Previous post was at 08:32 PM ----------
or take part numbers directly to dealer and tell them "how you like them apples!"
Donnie Yukonie
Yates Caretaker
I use SUNknowledge all the time to appear smart :signs8:
M
mranum
Thanks a bunch! I think I'll take them numbers to town with me next time I go and see what they say. :happy107:
M
mranum
Changed the hinge pins and bushings on my right cargo door this afternoon. Holy chit was that a project! Ended up with a die grinder with a cut off wheel to cut the pin at the mating surfaces to get the door off then heat the ends with a torch. The bottom hinge wasn't too bad, or the bottom of the top hinge. But the head of the pin on the top hinge was a @#$%^&* *****!!!!!
Finally got it though. Shut nice but still didn't open very good. Finally figured out the weatherstrip was folding inward between the doors as it closes and causes a bind when you go to open it. Guess that will be added to the list to work on.
BlacktopBandit76
