Question about light bulb sockets
danimalmax
louisiana
does anyone know what the socket is called that you plug 9005 bulbs into, and where to get some? i want to cut off the ones for my DRLs and replace it with that so i can put a 9005 bulb there and silicone it in place
DarkTahoe00
IN
Yea I saw some at Autozone cuz I was thinking of do the same thing!
HMFDZ28
Hunt Sta, NY
You have to check what the wiring is rated for... and you will probably melt the lense. But good luck lol
danimalmax
danimalmax
louisiana
thats why im gunna take off my clear corners and test it on my old set first
HMFDZ28
Hunt Sta, NY
Thats one way... just have to keep in mind that these will be on all the time... and the heat over time it bad on it.
For an example the 98-02 Camaros have a problem with the DRL's melting the housings on a lot of clear corners... best fix was to bypass the DRL's.
Not sayin dont do it by any means... Best of luck with it man!
danimalmax
danimalmax
louisiana
hm, what i really want them for is my current 8 high mod, what if i just make them not come on all the time and only for when i switch my brights on?
actually wont turning that light knob on my dashboard make them not come on and the orange ones to the outsides instead?
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
did u silicone them in place?
you dont need to. They fit just fine. But the silverado uses a different bulb. The 9005 is the exact same as a 9145(Stock silverado fog bulb) except for wattage. What he did wont work on a tahoe as the fog light housing is different. Also The silverados fog light housing is HUGE. So it can take the extra heat.
OldWYLawman
