PPV radiator part #
GranPrix
Does anyone know the part # for the 2011 ppv radiator? Gmpartsdirect has two, one with HD cooling and one with out but i'm not sure which we have. I'm assuming with the HD cooling... Has anyone swapped out their radiator?
1800radiator.com
p/n: 103285
lifetime warranty and it is slightly better than oem spec 1 3/8 thickness and they have added the drain **** back that gm deleted
and yes I am 100% certain it will fit the PPV and yes it has the oil cooler connections also
and by the way HD cooling is just a higher rating electric fan with more fins on it and higher amp draw, it makes no difference fitment wise other than the addition of the oil cooler lines to the radiator
GranPrix
GranPrix
Awesome, just ordered one. Thank you!
Ihaveatahoetoo
