Power Steering
Deiter
I am lossing power steering fluid at a fast rate. It doesn't look like its coming from the steering rack, does anyone have any idea of what I need to fix and an idea of the cost?
2001 chevy tahoe
5.3 v8
4-Wheeldrive
exp500
Until you look you are shotgunning parts! Only a few things that can leak. start at pump and work your way to steering.
Try rockauto for prices/parts. They sponsor here with a discount too.
Cbncanada
Check your master brake cylinder system. Some units use the power steering pump to boost the brakes.
SnowDrifter
Washington. The desert side not the Starbucks side
At risk of sounding like a smart ass, have you looked?
Everything on a vehicle is a wear item. You could be leaking from anywhere. Until you determine where the leak is, you're guessing and checking.
Also, I'd like to verify: Steering rack? Our vehicles don't use a rack, they use a recirculating ball box. It's well.... A box looking thing on the drivers side, on the front of the frame. Just want to see if it's a case of wording / modified vehicle / wrong forum section :)
treehan77
TYF Fiend
Crestview, FL
Could be your hydro boost unit if you have one too, I changed mine cause it was always seeping
Deiter
Deiter
Found the problem. Two fittings became loose just needed to be tighten.
You probably have loose fittings, see if anything needs to be tightened. :mad:
waiteben84
