Power Steering Leak, Need Help
TTZ06
Houston, TX
I am told there is a seal behind this cast part. Can this part be serviced without pump removal? How do you get the bolts out?
TTZ06
TTZ06
Houston, TX
its coming from where the cast block meets the pump. Ill go see if I can get a better pic
No better pic in the dark
Tbruz
Windham NH
That's the port for the variable speed assist on the PS pump.
There is a o-ring between that cast part and the PS pump body.
There are also a few o rings inside that part as well if I remember correctly
I do not think you can take that off without removing the PS pump.
You can get the O-ring seperately or as part of a PS pump rebuild kit.
*15825938
SEAL KIT
$14.60
*26020642
SEAL
$6.11
If $$ isn't an issue you can also get a rebuilt PS pump with that port on it already.Cardone Remanufactured - Power Steering Pump
Part # 20-8748FV1
Tbruz
kelly1
Central Kansas
Pay attention to the reman or new p/s pump you buy. I just installed a reman on my 97 tahoe yesterday and it came with no sensor or cast piece. I had to remove the existing one from my old pump.
I did get all the new o-rings I needed though. fyi.
Eickybobby5050
