Pops code when accelerating
erock198
Schenectady, NY
03 Yukon xl Denali 6.0L
I don't know if it is bad gas or what? When I romp on the pedal I get a code. It happens more times than none. I have a new in tank pump
thoughts?
rich5368
Cheyenne, WY
Just shooting from the hip with no info, a code under load to me could be pinging/knocking. Could be a sensor going bad and picking up false knock. Could be a million other things. Pinging can definately be caused by bad gas so either way I'd get this checked out immediately.
erock198
erock198
Schenectady, NY
the light goes off after a day or so. usually before i get a chance to have it checked but i will next time
ATL
your ecu stores codes, itll prob be in there even if the light isnt on
hoe
sounds like a multiple random misfire. But we need codes to tell. It only flashes the MIL as the problem is occurring, you could also use a scan tool.
gitrduun
If you don't fire on all cyl at any time for more than a certain number of revs you will pop a code but your engine light will flash too. Get the actual code numbers, if you have on star and are subscribed you can call them when it comes on(from inside your vehicle) and get them to tell you the code that shows up, then post it.
-j
erock198
erock198
Schenectady, NY
P0101
Mass Air Flow (MAF) Circuit Range/Performance Problem
Basically this means that there is a problem with the Mass Air Flow (MAF) sensor or circuit. The PCM detects that the actual MAF sensor frequency signal is not within a predetermined range of the calculated MAF value for more than 4.0 seconds. Other MAF sensor circuit DTC trouble codes are P0100, P0102, P0103, and P0104.
erock198
erock198
Schenectady, NY
bumpity only because I edited the last information.
Tried cleaning the MAF sensor and the boot area but still getting the code
erock198
erock198
Schenectady, NY
Bought myself one of these:
OBD2 Bluetooth
And a MAF sensor but I"m still getting the code. Now I get loss of power when I romp on it just before the code pops whereas withthe other MAF I had power but the code popped....
southboundchicken
Jacksonville fl.
my truck was poping up a code when getting ******* the gas and i was being passed by a v.w. bug :( ( no power) ...swapped out the fuel filter and shazam !!! no code and increased power :rockit:.... how long has it been since replacing your filter ?
JeffK
